sometimes , It’s giving problem in application load in hardware .
while i dump my application,
it gives “Unhandled Exception” like “System.NullReferenceException occurred in Microsoft.SPOT.TinyCoreRME.dll”
after that my application can not being execute in hardware
[line]
yes it is giving problem in simple application too
and one more thing i want to tell that , i am using this hardware continuous from last 2 month,
i did not switch of this from last 2 months, so can it be reason for this problem ?
because if i will make if off for 1 week or more , it will again start and i can dump my code into hardware
Null Reference exception typically means something you’re trying to access has been GCed from under you. It’s your code. You have to figure out what it is by DEBUGGING IT. Breakpoints. Watched Variables. Simplify your app. Show us a repro.
We’re all here for you but you have to help yourself dude, we can’t debug your code remotely
