I have used the example from the documentation to create a wifi connection.
I have checked that the wifi SSID is available, that I have joined it … however, I do not get a IP address (DHCP)
netif.Open();
netif.EnableDhcp();
netif.EnableDynamicDns();
netif.Join(ssid, password);
while (netif.IPAddress == “0.0.0.0”)
//sleep etc
never returns an address …
:wall:
@ Robert24 - Can you try to connect to a different router or turning off security?
I’m able to simulate this with this code:
using GHI.Networking;
using G120 = GHI.Pins.G120;
public partial class Program
private static WiFiRS9110 netif;
NetworkChange.NetworkAvailabilityChanged += NetworkChange_NetworkAvailabilityChanged;
NetworkChange.NetworkAddressChanged += NetworkChange_NetworkAddressChanged;
netif = new WiFiRS9110(SPI.SPI_module.SPI2, G120.P1_10, G120.P2_11, G120.P1_9);
netif.Open();
netif.EnableDhcp();
netif.Join("WLANEmrol2", "***");
Thread.Sleep(1000);
Debug.Print("Ip address in main : " + netif.IPAddress);
private static void NetworkChange_NetworkAddressChanged(object sender, Microsoft.SPOT.EventArgs e)
Debug.Print("Network address changed to " + netif.IPAddress);
Thread.Sleep(2000);
if (netif.IPAddress != "0.0.0.0")
//The network is now ready to use.
Debug.Print("Connected - IP=" + netif.IPAddress);
private static void NetworkChange_NetworkAvailabilityChanged(object sender, NetworkAvailabilityEventArgs e)
Debug.Print("Network availability: " + e.IsAvailable.ToString());
Output in debug window shows a delay :
Network availability: True
Network address changed to 0.0.0.0
Ip address in main : 0.0.0.0
Ip address in main : 192.168.1.130
The address stay’s 0.0.0.0 in main as long as the sleep in NetworkAddressChanged is set, then it switching to the assigned address and NetworkChange_NetworkAddressChanged is not trigered again.
I do not have another router in range … if I use static address; it works ok.
I have also duplicated David’s code and still no ipaddress from DHCP.
David are you using 4.3?
Yes, i used 4.3 R5 on a Cobra II Rev B.
@ Robert24 - You get no ip address at all or also “delayed” ?
I have the same issue on 4.3 Cobra II WiFi. There is no “delay” - it never gets an address. I think I’m one release back from current. Static IP works fine.
@ ransomhall - Is it actual not getting a address with DHCP or is the NetworkChange_NetworkAddressChanged event not trigered?
@ david - when settings for DHCP the networkAddressChanged never fires … if I set a static address it fires …
@ Robert24 - Have long have you let it sit trying to get an address? Do you see an address assigned in your router?
@ John - Have left it forever but nothing … DHCP is managed by our windows server!
@ John and there appears to be no entry for the cobra II … all entries can be accounted for?
@ Robert24 - Can you do a wireshark capture on your DHCP server to see what sort of traffic is going between the server and the Cobra?
Another first; I will download wireshark and attempt to monitor; maybe need some hints as I have never used it before!
