I’m newly back into programming after a 25 year diversion, and I’m brand-new to embedded processors; Yikes! I’m using a Fez Cobra and trying to use XmlReader to read from an RSS website. I suspect that my problem has more to do with the network setup than the XmlReader. My sample code including output is below. Any help that you can give me would be greatly appriciated. Thank you, Carl
using System.Net;
using System.Net.Sockets;
using System.Text;
using System.Xml;
using System.IO;
namespace FEZ_Cobra_Console_Application1
// PROGRAM INTENDED TO RUN ON FEZ COBRA
if (Microsoft.SPOT.Net.NetworkInformation.NetworkInterface.GetAllNetworkInterfaces().Length < 1)
Debug.Print("No Active network interfaces. Bombing out.");
Thread.CurrentThread.Abort();
Microsoft.SPOT.Net.NetworkInformation.NetworkInterface NI = Microsoft.SPOT.Net.NetworkInformation.NetworkInterface.GetAllNetworkInterfaces()[0];
if (NI.IsDhcpEnabled == false)
Debug.Print("Enabling DHCP.");
NI.EnableDhcp();
Debug.Print("DCHP - IP Address = " + NI.IPAddress + " ... Net Mask = " + NI.SubnetMask + " ... Gateway = " + NI.GatewayAddress);
Debug.Print("Renewing DHCP lease.");
NI.RenewDhcpLease();
XmlReader xmlDoc;
try
WebRequest aRequest = WebRequest.Create("http://rss.cnn.com/rss/cnn_us.rssurlStr");
WebResponse aResponse = aRequest.GetResponse();
xmlDoc = XmlReader.Create(aResponse.GetResponseStream());
Debug.Print("About to do XML Read");
do
xmlDoc.Read();
Debug.Print(xmlDoc.Name);
while (!xmlDoc.EOF);
Debug.Print("XML Read completed");
xmlDoc.Close();
catch
Debug.Print("Error doing Xml Read");
FEZ COBRA OUTPUT IS AS FOLLOWS:
DCHP - IP Address = 10.0.0.25 ... Net Mask = 255.0.0.0 ... Gateway = 10.0.0.60
#### Exception System.Xml.XmlException - 0xdd000000 (1) ####
#### Message:
#### System.Xml.XmlReader::Read [IP: 00d1] ####
#### FEZ_Cobra_Console_Application1.Program::Main [IP: 00e8] ####
A first chance exception of type 'System.Xml.XmlException' occurred in System.Xml.dll
The thread '<No Name>' (0x1) has exited with code 0 (0x0).
Done.
