Is it OK to power the Cobra III straight from a 12v vehicle supply, in that can it handle the noise etc?
Cheers
Cheers
yes, it has a decent power supply on it, and can take up to 30v (as per silkscreen) meaning you shouldn’t have any issue unless your alternator is massively out of whack
@ wolfbuddy - Decouple that with a capacitor. When the starter is operating, you basically have no power
Thanks for the replies. The range 7V to 30V seemed to be suitable for both 12V and 24V vehicle systems but It’s always worth checking with those in the know.
@ Mr Smith - that’s a good observation, however I wouldn’t expect the battery voltage to drop below 10V under cranking load unless there was something wrong with the battery/starter/wiring.
