Hi.
I am using wifi on board, static IP, static DNS. Nothing is different when using dynamic IP/DNS. (I get IP when using dhcp).
The problem is, that this code always freeze when I debug program. If I reset Cobra II, I get response (Time from local PHP). My URL is: “http://192.168.1.5/Process/Microcontroler/GetDateTime.php”
_request = (HttpWebRequest)HttpWebRequest.Create(url);
_request.Method = "GET";
_request.Timeout = 30 * 1000;
response = _request.GetResponse(); //here the program freeze when debugging
Both ways freeze. Stepping over the code or just run it.
I tried 10 times today. When debugging it freeze. When not, it works.
My php code is (just in case):
I installed netmon.
Appache server log did log access when debugging.
When I clicked reset, a line is added to access log:
192.168.1.201 - - [09/Mar/2013:09:19:47 +0100] “GET /Process/Microcontroler/GetDateTime.php HTTP/1.1” 200 19
The Microsoft Network monitor also did not cache any request when debugging. When I clicked reset:
138 9:19:47 9.3.2013 143.3757138 192.168.1.201 192.168.1.5 ARP ARP:Response, 192.168.1.201 at 00-23-A7-1F-9D-B1
135 9:19:47 9.3.2013 143.3105195 192.168.1.201 224.0.0.1 IGMP IGMP:IGMPv2 Membership Report {IPv4:17}
I read about update, but didn’t think it will fix anything, because nobody mention any similar problems.
The description said:
[quote]We believe that we have finally solved the DCHP/Socket creation error with G120.
We have corrected the issue with sending and receiving data over serial simultaneously. [/quote]
Nothing describes my problem.
