Hello,
Does anyone have a schematic or pin layout to show which pins are used for each gadgeteer socket on the Cobra II extender board?
Thanks,
Paul
Hello,
Thanks,
Paul
Will you be using it with Gadgeteer or without?
With. I was going to order the extender board but it wont fit in my current case so I was just going to wire the socket up myself in the same way via a breadboard
Thanks for the reply
Paul
schematic has been uploaded to the extender
Brilliant thanks Gus
@ Gus -
Thanks!
I received one yesterday and I’ll probably need that info!
Actually, most users will use gadgeeer designer and this is built in already. You do not need the schematics or any info, just plug in your modules and they will work.
