Just got my first Gadgeteer mainboard and decided to hook it up to the N7 to try out any sample code. Problem is that the signal seems to be out of sync and the screen flickers. See pictures.
One is of the board booting up. The other is an attempt to draw a filled in rectangle.
using System.Collections;
using Microsoft.SPOT.Touch;
using GHI.Hardware.G120;
using GHI.Premium.Hardware;
using GHI.Premium.Hardware.LowLevel;
using Gadgeteer.Networking;
using GT = Gadgeteer;
namespace GadgeteerApp1
public partial class Program
GTM.GHIElectronics.Display_N7 N7 = new GTM.GHIElectronics.Display_N7(3,2,1);
N7.SimpleGraphics.DisplayRectangle(GT.Color.Magenta, 4, GT.Color.Purple, 10, 10, 400, 200);
This is my current source(Not initializing in the designer code in this iteration). Prior to this I have also tried the default display_N7 object creation through Designer and also using an Configuration.LCD.Configurations object at program start to try and configure display per CP7 “non-gadgeteer” example.
I haven’t been able to find much on this issue. Only a pixel clock divider flickering issue that I’ve found while browsing Hydra dev guide, which I’m not sure how to attempt.
Am I missing something?
