Since the first 3 analog pins are routed to the same socket as the touchscreen I, does that mean there is no way to use them? (Since I have a CP7 attached)
Why can’t you? These pins are GPIO as well, not just touch.
With the touchscreen plugged in, how do I get access to them? I didn’t see them on the hole-throughs.
But you are using CP7 which does not use touch but uses i2c.
I’m confused. So I’m looking at the back of my cobra II:
https://www.ghielectronics.com/img/www/products/482-3_large.jpg
Where to I wire up for Analog_0?
Oh I see now. There is only one I type socket which is also analog. You can use cobra extender board or write things using breakout module or directly. Use the extender board as a reference.
I guess I understand. I’ll get a break out module and I’m sure figure it out from there.
Which pins are used by the I socket?
