Cobra case bezel
A couple of questions…
  • Does a template file exist for use with the Cobra case that has the dimensions required for a bezel overlay? Or are accurate the dimensions detailed anywhere? Perhaps the case cutouts?
  • If we make an overlay, should it cover the touchscreen or simply surround it?
I.e. will the touchscreen operate with a transparent plastic layer on it?
Thanks!
http://tinyclr.com/forum/10/1284/
These are the GHI designs. You can have a look at them.
Yes and No…
Yes it will work but the touch accuracy will be diminished a little bit.
FEZ Cobra OEM Boxes ship with a plastic screen protector and the touch is tested with the plastic on it.
As for the exact dimensions, I will try to see what we can do to get them added to the description of FEZ Cobra OEM Box.
