I’m building a handset which receives an image to dsiplay on TE35 via bluetooth from a PC in response to a key press on same handset, so it needs to be fast, surprising my users don’t like to wait! I’m willing to impose only monochrome image when operating over bluetooth since the data rate is so low. My problem is to keep the payload as small as possible my design sends an indexed bitmap with bitcount 1 to the handset, but when the NETMF receives the image and I pass to GT.Picture class I get CLR_NOT_SUPPORTED exception.
I have several options available 1) Inflate the image to 8bpp index on handset end in RLP (so its fast). Means I have to do some low level bit manipulation, not the end of the world but I’m a purist and I would like to do it the “right” way; or 2) Modify the .Net MicroFramework so it supports images with 1 bpp. My hesitation is that I’ve never had to compile the NETMF and I’m worried I opening a proverbial “Pandora’s box”.
Has anyone had success with modifying and recompiling Framework 4.3 on FEZ Spider II?
I’m aware Wifi is probably better suited but it can;t match the easy of setup of Bluetooth.
I’m using WT12 via UART running at 921600baud.
Thanks in advanced for all your support.
I only have this last issue to work out and I can start churning out hundreds of these devices on the G120.
Kind regards
David
