Hello, so I have recently been trying to get my cellular radio module working for SMS, and came across this error before I could even really get into it.
Using mainboard GHI Electronics FEZSpider version 1.0
#### Exception System.Exception - CLR_E_PIN_UNAVAILABLE (1) ####
#### Message:
#### Microsoft.SPOT.Hardware.Port::.ctor [IP: 0000] ####
#### Microsoft.SPOT.Hardware.OutputPort::.ctor [IP: 0006] ####
#### Gadgeteer.Interfaces.NativeDigitalOutput::.ctor [IP: 0018] ####
#### Gadgeteer.Interfaces.DigitalOutput::.ctor [IP: 0031] ####
#### Gadgeteer.Modules.Seeed.CellularRadio::.ctor [IP: 0031] ####
#### Core.Program::ProgramStarted [IP: 007a] ####
#### Core.Program::Main [IP: 0015] ####
A first chance exception of type 'System.Exception' occurred in Microsoft.SPOT.Hardware.dll
An unhandled exception of type 'System.Exception' occurred in Microsoft.SPOT.Hardware.dll
My code is simply this:
private CellularRadio cellRadio;
//Socket #4 supports type 'K'
cellRadio = new CellularRadio(4);
cellRadio.DebugPrintEnabled = true;
cellRadio.PowerOn(50);
cellRadio.SendATCommand("AT");
cellRadio.SendATCommand("AT+CPIN=0000");
cellRadio.SendATCommand("AT+CMGF=1");
cellRadio.SmsRetrieved += new CellularRadio.SmsRetrievedHandler(cellRadio_SmsRetrieved);
cellRadio.SmsReceived += new CellularRadio.SmsReceivedHandler(cellRadio_SmsReceived);
cellRadio.ModuleInitialized += new CellularRadio.ModuleInitializedHandler(cellRadio_ModuleInitialized);
And the error occurs on the first line in ProgramStarted(); where I try to initialize the module.
Unfortunately, this is not the first time I have come across this error either. I tried to get my SD card module to work a couple of days ago, in Socket 5 (which supports type ‘F’), and I got the same CLR_E_PIN_UNAVAILABLE (1) Error
Pretty frustrated at this point because I cannot find any resources really addressing how to resolve this error. I have triple checked my program and there is no other module / object working on the sockets I am requesting for either the Cellular Radio module, or the SD Card module.
At this point I’m thinking maybe there is a problem with my board? I really hope not. Thanks for any help!
