I get this error while compiling:
“CLR_E_OUT_OF_Range” in MMP file
Project cannot be compiled… it have worked fine, and out of no ware I got this error.
There is no syntax errors.
I have tried to make a new project and copy the code - same thing.
A littlebit more details would help to understand what might be going wrong (post your code)
I was just writing code and pressed F6 compile on the go - no problems.
They I made a new simple if statement… then I got the Error.
I found on the net, and example with a file that was OK with,
int iva = 44;
But changed to
int iva = 445;
Caused same error.
It seems like a kind of limitation…
MMP should be a Meta Data Processor…
I tried to move code to another file - did not help.
But, enabling “Optimize Code” under “Build” in the “Project Properties” made the Error Message go…
