Hi. I’m trying to compile a program for my EMX board and am getting a compiler error. All it says is “CLR_E_ENTRY_NOT_FOUND” and that the file is “MMP”. I can’t find the error on Google and have no idea what might be causing the issue. References appear to all be found. Through experimenting, I did find that unchecking “Generate native stubs for internal methods” underneath project / properties / .NET Micro Framework resolves the compiler error, but then I get:
Assembly: 4DPowerBar (1.0.0.0) needs assembly ‘GHIElectronics.NETMF.Net’ (4.1.3.0)
Assembly: 4DPowerBar (1.0.0.0) needs assembly ‘System.IO’ (4.1.2821.0)
Assembly: GHIElectronics.NETMF.IO (4.1.6.0) needs assembly ‘GHIElectronics.NETMF.System’ (4.1.6.0)
Error: a3000000
The program ‘[7] Micro Framework application: Managed’ has exited with code 0 (0x0).
Waiting for debug commands…
Any ideas would be appreciated.
Thank you,
Dustin
