microt
November 30, 2010, 8:35pm
1
Please do not tell I have messed up 4.0 and 4.1 But as far as I know I have not.
Would you please try extracting the hex file from the ChipX board.
I am using COM port and have been trying for 4 hours now
Every time it gets stuck. I have waitied for 15 minutes to extract it. Then I cancel it
The deploying of the ER_CONFIG, ER_FLASH works ok.
microt
November 30, 2010, 9:23pm
2
I have now installed everything on a fresh PC.
Hex file Extract with USB also failed
User_5
December 1, 2010, 9:53am
3
It is slow on ChipworkX and may take few minutes… But eventually it works fine. This is because MFDeploy examines every 128 bytes of memory and ChipworkX has a lot more memory I think…
User_5
December 1, 2010, 9:55am
4
Make sure you have updated both the TinyBooter and Firmware to the latest version, maybe this is why you having problems.
microt
December 1, 2010, 6:07pm
5
ok…finally I was able to download the hex file.
It took 30 minutes
But deploying it again went fast like the EMX.
One thing I observed is EMX usually resets on it own after deployment. And you can ping it. But ChipX needed a reset.
