I’m trying to implement USB connection between ChipworkX and PC. I would also like to be able to use the same cable for debugging. I’ve read around and the solution I’ve found is
Using that the computer recognizes the virtual COM port, also the debugging interface. All the drivers are installed and they seem to be working fine. I can deploy with no problem. When I try to debug, however, the whole device freezes upon calling the StartCDC_WithDebugging() method. I tested the virtual COM port communication and it works fine as long as I’m not debugging. So my question is, is it possible to use the virtual COM port and debugging at the same time? And if it is, what am I doing wrong? Thanks
I’ve checked that thread and the drivers are installed and they seem to work fine.
The problem is in order to debug, I need to disable the StartCDC_WithDebugging() call. Without disabling that I can only deploy.
Also the virtual COM communication works fine - I can receive/send data to/from the device (as long as I’m not debugging).
