I just powered up a ChipworkX module to erase and update the CLR and I think I might have bricked it. MFDeploy detected it so I erased the CLR and managed code area, and then MFDeploy crapped out. That was because it was no longer able to communicate through USB to the ChipworkX module. I tried changing the Up,Down,Select pin polarity to bring it up in boot mode to no avail, my computer does not detect it as a USB device.
Again here are the steps I took in MFDeploy:
Powered up ChipworkX (Up,Down,Select floating)
Opened MFDeploy
Selected USB as the communication interface
Pinged the ChipworkX module, it responded correctly
Clicked the Erase button, it start erasing but after about 5 seconds MFDeploy crashed
It turned out that my USB hub was on the blink. Thanks for the suggestion Mike.
So now I am back to the issue that made me think I needed to update the CLR. I am getting a “System.Argument” exception at the line of code that sets the lcd configuration. Attached is a screenshot. This same code worked fine on the EMX, and I’ve even copied the code from the FEZ 7 inch display example without any luck.
