I’m working with the chipworkx module, with DHCP.
In my application I’m using enableDHCP(), to ensure dynamic network settings after starting my application.
It works fine - no problems any more. In my network I’m getting the IP 192.168.0.4.
But trying to deploy my application (hex-file) with MFDeploy via network to the chipworkx module, fails very often. I saw that after rebooting, IP is changed to 192.168.0.8 for a short time. Checking the network settings with MFDeploy shows, that this IP (192.168.0.8) is set as static IP, but can’t be changed, because of the active DHCP mode.
Why does the module always start with the static IP?
I believe that was done so the ChipworkX could always boot fast (and not rely on a DHCP server). I have a DHCP option in my software, but it is saved to a configuration file and I check it after the program loads and if it is set for DHCP then I enable DHCP and try to get an IP address and so on.
I would say for deploying via network you probably want to use a static IP address. I’ve only deployed via USB though.
I still have the problem with updating my chipworkx module via ehternet with DHCP settings. My IP range ist from 192.168.0.2 to 192.168.0.100. Normally the chipworkx gets the 192.168.0.8.
Using MFDeploy and rebooting (Debug - Reboot CLR) or updating my application leads both to a restart and the IP 192.168.1.155. At this point firmware update stopps. It’s always the same IP. How can I change this behaviour?
I know that DHCP is disabled on power up. But enabling it in my application and trying to make an application update with MFDeploy always fails.
Is there a way to make an update with enabled DHCP?
You can’t load “application deployment” from MFDeploy using Ethernet. But, premium offers have in-field update feature so you can actually automate your update and even use Ethernet.
He wants to know why he can use MFDeploy to deploy via Ethernet with a static address, while it does not work with DHCP,
The fact that you told him, in port #3, that DHCP is disabled on boot does not seem to matter.
@ Mike - Yes but what really confuses me is that whenever MFDeploy is used to transfer files, the system switches to TinyBooter. And we never supported Ethernet on TinyBooter IIRC. So how did it ever work?!!!
But you are right Mike, there is NO DHCP on power up no matter what you do. Device will always use the static IP it has.
