Charging Multiple i Devices
I’m looking for some advice from the EEs out there. My company has dozens of iPhones/iPads/Android tablets, etc. and I’ve been asked to build an inventory solution for these that will involve cataloging and check in/out. More to come on this later. The problem I want to discuss now is how to have all these devices in the storage device charging at the same time and in as little space as possible. In other words, I don’t want to have a separate power supply for each device.
My best idea so far is to use a PC power supply (ex. +5V 25A) and wire up some USB ports to the +5V output. Assuming all the devices are iPads that can pull 2.1A each then I could charge 11 or so off one power supply. So, my question is - is it enough to just supply +5V or does the charger need to have more intelligence than this solution would provide?
The reason I’m looking at this problem first is that our CEO approached me with a very similar problem today. He travels with several of these devices and wants a single solution for charging them all on the road instead of carrying a bag full of chargers around. If this will work then I’ll build something very special for him.
Any other recommendations for this?
There is doco on how to get an iDevice to charge out “there”; it’s not as simple as wiring up the appropriate power supply, but from memory it’s not that hard either (the device senses current on a data line or something equally weird).
I believe the MintyBoost page on Adafruit talks about this …
Here it its: MintyBoost - The mysteries of Apple device charging
I have tried to charge an iphone by modding a 12v Car Cigarette Lighter adapter to an USB A receptacle. I did not have much luck, the phone would charge for a short duration and display a “This accessory is not made …” error.
I have read the article that Brett has pointed out, but need to try it sometime.
For travelling I got one of these and love it. USB Battery Pack for Raspberry Pi - 3300mAh - 5V @ 1A and 500mA : ID 962 : $59.95 : Adafruit Industries, Unique & fun DIY electronics and kits . It handles fast charge, but does get warm. It comes with a crapload of adapters for all common device types. When not in range of an AC plug to charge it, I use a small homemade solar panel rig, and bet it would be easy to find a safe car charger for it. There are other similar products in varying capacities.
Thanks for the info, guys! One other question - in the MintyBoost they are using an LT1302 to step up the 3V3 to 5V. If I’m using +5V directly from a quality power supply, do you recommend adding something between the power supply and the iPad to regulate or would I be safe just running the +5V directly to the USB?
That looks nice but I don’t think it’s going to work for what I need. I’ll need to be able to charge at least 4 devices simultaneously. That device can only supply a max of 1A. A single iPad can consume 2.1A.
The minty is not designed to charge a tablet, but is fine (albeit slow) for smartphones and other stuff that draws a maximum of 500mA.
Charging 4 devices at once “on the road” will obviously require something big and beefy. It might weigh more than all those chargers, and draw attention during airport screening…
