Hi guys,
With 4.2 framework I was using a custom CharacterDisplay class that allowed me to set & show custom characters by means of 2 functions that are named CustomCharSet and CustomCharPrint.
Now I want to upgrade to 4.3 framework so I downloaded the CharacterDisplay 4.3 class (here: https://bitbucket.org/ghi_elect/gadgeteer/src/985ade835fd675b6b1cf004aa4bc732eca8d5244/Modules/GHIElectronics/CharacterDisplay/CharacterDisplay_43/CharacterDisplay_43.cs?at=master ) and I copied the 2 functions I need for custom characters… but something doesn’t work.
Can you help me to understand where is the error?
Thx, this is the class I edited:
namespace Gadgeteer.Modules.GHIElectronics
/// <summary>
/// A CharacterDisplay module for Microsoft .NET Gadgeteer
/// </summary>
public class Display_HD44780_AGI_43 : GTM.Module
private GTI.DigitalOutput lcdRS;
private GTI.DigitalOutput lcdE;
private GTI.DigitalOutput lcdD4;
private GTI.DigitalOutput lcdD5;
private GTI.DigitalOutput lcdD6;
private GTI.DigitalOutput lcdD7;
private GTI.DigitalOutput backlight;
private int currentRow;
private static byte[] ROW_OFFSETS = new byte[4] { 0x00, 0x40, 0x14, 0x54 };
private const byte DISP_ON = 0x0C;
private const byte CLR_DISP = 1;
private const byte CUR_HOME = 2;
private const byte SET_CURSOR = 0x80;
private void WriteNibble(byte b)
this.lcdD7.Write((b & 0x8) != 0);
this.lcdD6.Write((b & 0x4) != 0);
this.lcdD5.Write((b & 0x2) != 0);
this.lcdD4.Write((b & 0x1) != 0);
this.lcdE.Write(true);
this.lcdE.Write(false);
Thread.Sleep(1);
private void SendCommand(byte command)
this.lcdRS.Write(false);
this.WriteNibble((byte)(command >> 4));
this.WriteNibble(command);
Thread.Sleep(2);
this.lcdRS.Write(true);
/// <summary>Constructs a new instance.</summary>
/// <param name="socketNumber">The socket that this module is plugged in to.</param>
public Display_HD44780_AGI_43(int socketNumber)
Socket socket = Socket.GetSocket(socketNumber, true, this, null);
socket.EnsureTypeIsSupported('Y', this);
this.lcdRS = GTI.DigitalOutputFactory.Create(socket, GT.Socket.Pin.Four, false, null);
this.lcdE = GTI.DigitalOutputFactory.Create(socket, GT.Socket.Pin.Three, false, null);
this.lcdD4 = GTI.DigitalOutputFactory.Create(socket, GT.Socket.Pin.Five, false, null);
this.lcdD5 = GTI.DigitalOutputFactory.Create(socket, GT.Socket.Pin.Seven, false, null);
this.lcdD6 = GTI.DigitalOutputFactory.Create(socket, GT.Socket.Pin.Nine, false, null);
this.lcdD7 = GTI.DigitalOutputFactory.Create(socket, GT.Socket.Pin.Six, false, null);
this.backlight = GTI.DigitalOutputFactory.Create(socket, GT.Socket.Pin.Eight, true, null);
this.currentRow = 0;
this.SendCommand(0x33);
this.SendCommand(0x32);
this.SendCommand(Display_HD44780_AGI_43.DISP_ON);
this.SendCommand(Display_HD44780_AGI_43.CLR_DISP);
Thread.Sleep(3);
/// <summary>
/// Prints the passed in string to the screen at the current cursor position.
/// A newline character (\n) will move the cursor to the start of the next row.
/// </summary>
/// <param name="value">The string to print.</param>
public void Print(string value)
for (int i = 0; i < value.Length; i++)
this.Print(value[i]);
/// <summary>
/// Prints a character to the screen at the current cursor position.
/// </summary>
/// <param name="value">The character to display.</param>
public void Print(char value)
if (value != '\n')
this.WriteNibble((byte)(value >> 4));
this.WriteNibble((byte)value);
this.SetCursorPosition((this.currentRow + 1) % 2, 0);
/// <summary>
/// Clears the screen.
/// </summary>
public void Clear()
Thread.Sleep(2);
/// <summary>
/// Places the cursor at the top left of the screen.
/// </summary>
public void CursorHome()
this.SendCommand(Display_HD44780_AGI_43.CUR_HOME);
Thread.Sleep(2);
/// <summary>
/// Moves the cursor to given position.
/// </summary>
/// <param name="row">The new row.</param>
/// <param name="column">The new column.</param>
public void SetCursorPosition(int row, int column)
if (column > 15 || column < 0) throw new System.ArgumentOutOfRangeException("column", "column must be between 0 and 15.");
if (row > 1 || row < 0) throw new System.ArgumentOutOfRangeException("row", "row must be between 0 and 1.");
this.currentRow = row;
this.SendCommand((byte)(Display_HD44780_AGI_43.SET_CURSOR | Display_HD44780_AGI_43.ROW_OFFSETS[row] | column));
/// <summary>
/// Whether or not the backlight is enabled.
/// </summary>
public bool BacklightEnabled
get
return this.backlight.Read();
set
this.backlight.Write(value);
public void CustomCharSet(byte memory_position, byte charRow0, byte charRow1, byte charRow2, byte charRow3, byte charRow4, byte charRow5, byte charRow6, byte charRow7)
//first command starts the character definition by setting 1 of the 8 memory locations dedicated to storage.
switch (memory_position)
case 0:
SendCommand(0x40);
break;
case 1:
SendCommand(0x41);
break;
case 2:
SendCommand(0x42);
break;
case 3:
SendCommand(0x43);
break;
case 4:
SendCommand(0x44);
break;
case 5:
SendCommand(0x45);
break;
case 6:
SendCommand(0x46);
break;
case 7:
SendCommand(0x47);
break;
//next 8 commands send the character definition
SendCommand(charRow0);
SendCommand(charRow1);
SendCommand(charRow2);
SendCommand(charRow3);
SendCommand(charRow4);
SendCommand(charRow5);
SendCommand(charRow6);
SendCommand(charRow7);
Thread.Sleep(1);
public void CustomCharPrint(byte memory_position)
case 0:
SendCommand(0x80);
break;
case 1:
SendCommand(0x81);
break;
case 2:
SendCommand(0x82);
break;
case 3:
SendCommand(0x83);
break;
case 4:
SendCommand(0x84);
break;
case 5:
SendCommand(0x85);
break;
case 6:
SendCommand(0x86);
break;
case 7:
SendCommand(0x87);
break;
