Unknown
September 5, 2010, 12:21am
1
Hello,
So since my Domino didn’t come with a jumper for changing the debug mode, I was wondering which pin I have to short to ground to enable serial port debugging?
EDIT: Ok so I know it’s PWM 4, my question is about how I go about shorting it since there is no jumper.
si1
September 5, 2010, 2:46am
2
You can use a short length of wire…
MarkH
September 5, 2010, 3:36am
3
If you have an old pc lying around, just grab a jumper off it’s motherboard. ;D
A while ago I have stripped all jumpers of every motherboard I had lying around. These things come in handy everywhere
si1
September 5, 2010, 11:37am
5
PC jumper isn’t going to work for him since the pin is just a pad, he really does need a length of wire. Unless that is, he solders headers there.
User_12
September 5, 2010, 12:15pm
6
Chris,
That’s not totally correct. there is a mode jumper place ready on the board. Take a look at the board.board.
[url]http://www.tinyclr.com/images/products/TCLR-0001_large.jpg[/url]
si1
September 5, 2010, 12:24pm
7
Hi Joe, actually it is
There is a pad that you can short, but they were talking about using a PC jumper to short it. Unless you solder headers onto that pad, you can’ use a PC jumper.
Unknown
September 5, 2010, 2:52pm
8
That’s right. The documentation says that there is a jumper, but there are no pins where this jumper should be. So I just assumed that there was another way. So then either mine didn’t come with a jumper or…
Time to warm up the soldering iron sigh since I want to be able to go back to using USB on the fly.
nielsnl
September 5, 2010, 3:36pm
9
Just to be sure, you have seen it.
When you use the mode pin’s you cant use the Led anymore.
It uses the same pin.
greetings
nielsnl
September 5, 2010, 3:41pm
10
When you use the mode pads, you cant use the on-board Led anymore.
greetings
User_12
September 5, 2010, 4:26pm
11
BTW The jumper is only needed on system (FEZ Domino) boot-up. You can remove the jumper right after that and your LCD will work again. 8)
Unknown
September 5, 2010, 4:28pm
12
What jumper? It’s just pads
Instead of jumper, put 1K resistor and the pin will always be functional
Unknown
September 5, 2010, 4:29pm
14
1K ohm across the pads? Or from the signal pad to ground
The second pad is ground so it is the same thing
Just a few quick question regarding this.
why would someone want to debug via serial?
When debugging in serial, which COM port do you connect to?
Thanks.
To use USB for something else. See ebook USB Client section
Always COM1
Unknown
September 5, 2010, 6:05pm
18
OK so I’m soldering some pins onto the pads marked “Mode” and then I’m using a jumper across them (or a 1K ohm resistor).
Sounds ok.
Thanks Gus.
Oh great, as you would know I have fried my COM1. :-[ :’(
Unknown
September 5, 2010, 9:23pm
20
Side topic: how did you fry your com1 with out damaging the chip completely?
So Gus, once I remove the jumper and reboot the Domino will go back to USB debugging right?
