OK, this is my full code:
using System.IO;
using System.Text;
using Microsoft.SPOT.IO;
using GHIElectronics.NETMF.Net.Sockets;
using GHIElectronics.NETMF.Net.NetworkInformation;
using Socket = GHIElectronics.NETMF.Net.Sockets.Socket;
namespace EthernetFez
#region Variables estaticas
static byte[] ip = { 192, 168, 1, 144 };
static byte[] mac = { 0x28, 0x08, 0xDC, 0x15, 0xFF, 0x00 };
static byte[] subnet = { 255, 255, 255, 0 };
static byte[] gateway = { 192, 168, 1, 1 };
static Thread LecturaPuerto = new Thread(LecturaUDP);
static UInt16 seleccion = 0;
static Socket Servidor;
static IPEndPoint remoteEndPoint;
static EndPoint entradaremota;
static UInt16 Ipremota = new int();
static byte[] Salida = new byte[10];
static UInt16 NumPuerto = 0;
static Estructura_Modulos[] Modulos = new Estructura_Modulos[5];
#endregion
struct Estructura_Modulos
public int ModulosRed;
public string Respuesta;
public byte[] DireccionMac;
public byte[] DireccionIP;
public byte[] MascaraSubRed;
public byte[] PuertaEnlace;
InterruptPort BotonEntrada =
new InterruptPort((Cpu.Pin)FEZ_Pin.Interrupt.LDR, true,
Port.ResistorMode.PullUp,
Port.InterruptMode.InterruptEdgeHigh);
BotonEntrada.OnInterrupt += new NativeEventHandler(BotonEntrada_Interrption);
WIZnet_W5100.Enable(SPI.SPI_module.SPI1, (Cpu.Pin)FEZ_Pin.Digital.Di10, (Cpu.Pin)FEZ_Pin.Digital.Di9, true);
entradaremota = new IPEndPoint(IPAddress.Any, 100);
NetworkInterface.EnableStaticIP(ip, subnet, gateway, mac);
#region Carga datos de modulo local en la estructura
Modulos[0].Respuesta = "Unknown";
Modulos[0].DireccionMac = mac;
Modulos[0].DireccionIP = ip;
Modulos[0].MascaraSubRed = subnet;
Modulos[0].PuertaEnlace = gateway;
#endregion
public static void BotonEntrada_Interrption(uint puerto, uint estado, DateTime hora)
if (seleccion == 0)
Servidor = new Socket(AddressFamily.InterNetwork, SocketType.Dgram, ProtocolType.Udp);
Ipremota = 0;
#region Valores extraidos de la estructura
string txtcomando = "";
Debug.Print("Datos del modulo: " + Ipremota.ToString());
Debug.Print("Respuesta del modulo: " + Modulos[Ipremota].Respuesta);
txtcomando = "";
for (UInt16 i = 0; i < Modulos[Ipremota].DireccionMac.Length; i++)
txtcomando += Byte_ToHex(Modulos[Ipremota].DireccionMac[i]) + ":";
txtcomando = txtcomando.Substring(0, txtcomando.Length - 1);
Debug.Print("Direccion Mac: " + txtcomando);
txtcomando = Byte_ToText(Modulos[Ipremota].DireccionIP, '.');
Debug.Print("Direccion IP: " + txtcomando);
txtcomando = Byte_ToText(Modulos[Ipremota].MascaraSubRed, '.');
Debug.Print("Mascara de subred: " + txtcomando);
txtcomando = Byte_ToText(Modulos[Ipremota].PuertaEnlace, '.');
Debug.Print("Puerta de enlace: " + txtcomando);
#endregion
NumPuerto = 7100;
remoteEndPoint = new IPEndPoint(IPAddress.Parse("255.255.255.255"), NumPuerto);
Salida = Encoding.UTF8.GetBytes("WIZ220FIND");
Servidor.SendTo(Salida, remoteEndPoint);
string txtoutput = "";
for (UInt16 i = 0; i < Salida.Length; i++)
txtoutput += Convert.ToChar(Salida[i]).ToString();
Debug.Print(" Comando " + txtoutput + " enviado al puerto " + remoteEndPoint.Port.ToString());
NumPuerto = 1460;
Salida = Encoding.UTF8.GetBytes("FIND");
txtoutput = "";
Debug.Print(" ");
if (!LecturaPuerto.IsAlive)
LecturaPuerto.Start();
if (seleccion == 1)
ConexionTCPIP(Byte_ToText(Modulos[1].DireccionIP, '.'), 23);
Servidor.Send(Encoding.UTF8.GetBytes("Hello world!!!\r\n"));
Servidor.Close();
Debug.Print("Dato enviado y conexion cerrada");
if (seleccion >= 1)
seleccion = 0;
seleccion += 1;
public static void ConexionTCPIP(string TxtIP, int Puerto)
Debug.Print("Se ha seleccionado el puerto " + Puerto.ToString() + " para conectarse a la IP " + TxtIP);
Servidor = new Socket(AddressFamily.InterNetwork, SocketType.Stream, ProtocolType.Tcp);
remoteEndPoint = new IPEndPoint(IPAddress.Parse(TxtIP), Puerto);
Servidor.Connect(remoteEndPoint);
public static void LecturaUDP()
if (Servidor.Poll(-1, SelectMode.SelectRead))
Debug.Print("Leyendo modulo..."); Debug.Print(" ");
Ipremota++;
byte[] entrada = new byte[Servidor.Available];
int cuenta = Servidor.ReceiveFrom(entrada, ref entradaremota);
for (UInt16 i = 0; i <= 9; i++)
txtcomando += Convert.ToChar(entrada[i]).ToString();
if (txtcomando == "WIZ220find")
MakeEstructuraWIZ220(entrada);
MakeEstructuraFIND(entrada);
Modulos[0].ModulosRed = Ipremota;
Debug.Print(" "); Debug.Print(" ");
static void MakeEstructuraFIND(byte[] paquete)
byte[] direccionmac = new byte[6];
byte[] direccionip = new byte[4];
byte[] mascarasubred = new byte[4];
byte[] puertaenlace = new byte[4];
for (UInt16 i = 0; i <= 3; i++)
txtcomando += Convert.ToChar(paquete[i]).ToString();
Modulos[Ipremota].Respuesta = txtcomando;
for (UInt16 i = 4; i < 9; i++)
direccionmac[i - 4] = paquete[i];
Modulos[Ipremota].DireccionMac = direccionmac;
for (UInt16 i = 11; i <= 14; i++)
direccionip[i - 11] = paquete[i];
Modulos[Ipremota].DireccionIP = direccionip;
for (UInt16 i = 15; i <= 18; i++)
mascarasubred[i - 15] = paquete[i];
Modulos[Ipremota].MascaraSubRed = mascarasubred;
for (UInt16 i = 19; i <= 22; i++)
puertaenlace[i - 19] = paquete[i];
Modulos[Ipremota].PuertaEnlace = puertaenlace;
txtcomando = "";
#endregion
static void MakeEstructuraWIZ220(byte[] paquete)
for (UInt16 i = 10; i < 15; i++)
direccionmac[i - 10] = paquete[i];
for (UInt16 i = 16; i <= 19; i++)
direccionip[i - 16] = paquete[i];
for (UInt16 i = 20; i <= 23; i++)
mascarasubred[i - 20] = paquete[i];
for (UInt16 i = 24; i <= 27; i++)
puertaenlace[i - 24] = paquete[i];
txtcomando = "";
#endregion
static string Byte_ToHex(int number)
string hex = "0123456789ABCDEF";
if (number > 256)
return new string(new char[] { hex[(number & 0xF000) >> 12], hex[(number & 0xF00) >> 8], hex[(number & 0xF0) >> 4], hex[number & 0x0F] });
return new string(new char[] { hex[(number & 0xF0) >> 4], hex[number & 0x0F] });
static string Byte_ToText(byte[] Dir, char Separador)
string Txt = "";
string txt = "";
try
for (UInt16 i = 0; i < Dir.Length; i++)
Txt += Dir[i].ToString() + Separador.ToString();
txt = Txt.Substring(0, Txt.Length - 1);
catch (Exception ex) { Debug.Print("Error en: " + ex.ToString()); }
return txt;
