This look very sweet. Source code is found here http://www.serveurperso.com/temp/maths.txt
So I was wondering how fast (slow) this will be through NETMF. I converted the code to C# and I see somethign but not completely working!
Can you figure out why? Here is my C# code (runs in emulator, no need for hardware)
// Microcontroller graphic demo by Pascal Piazzalunga
// admin@ serveurperso.com http://www.serveurperso.com
namespace MFConsoleApplication3
static Bitmap LCD = new Bitmap(320, 240);
static int WINDOWX = 320;
static int WINDOWY = 240;
// INCREMENT = SCALE / sqrt(N) * 2
// Optimizer-friendly values
static int N = 1024; // Number of dots
static int SCALE = 8192;
static int INCREMENT = 512;
static int SPEED = 10;
static double PI2 = 6.283185307179586476925286766559;
//static char buff[512];
//SWIM_WINDOW_T win1;
static UInt16[] sine = new UInt16[SCALE];
static UInt16[] cosi = new UInt16[SCALE];
static void initialize()
int i;
for (i = 0; i < SCALE; i++)
sine[i] = (UInt16)(System.Math.Sin(PI2 * i / SCALE) * SCALE);
cosi[i] = (UInt16)(System.Math.Cos(PI2 * i / SCALE) * SCALE);
static UInt16 fastsqrt(UInt16 n)
UInt16 c = (UInt16)0x8000;
UInt16 g = (UInt16)0x8000;
for (; ; )
if (g * g > n)
g ^= c;
c >>= 1;
if (c == 0)
return g;
g |= c;
//void matrix(UInt16 xyz[3][N], UInt16 rgb[3][N])
static int t_matrix=0;
static void matrix(int[][] xyz, byte[][] rgb)
//static UInt32 t_matrix = 0;
UInt16 i;
int x = -SCALE;
int y = -SCALE;
UInt16 d;
int s;
for (i = 0; i < N; i++)
xyz[0][i] = x;
xyz[1][i] = y;
d = fastsqrt((UInt16)(x * x + y * y));
s = sine[(int)((t_matrix * 30) % SCALE)] + SCALE;
xyz[2][i] = sine[(d + s) % SCALE] *
sine[(t_matrix * 10) % SCALE] / SCALE / 2;
rgb[0][i] = (cosi[xyz[2][i] + SCALE / 2] + SCALE) *
(RED_COLORS - 1) / SCALE / 2;
rgb[1][i] = (cosi[(xyz[2][i] + SCALE / 2 + 2 * SCALE / 3) % SCALE] + SCALE) *
(GREEN_COLORS - 1) / SCALE / 2;
rgb[2][i] = (cosi[(xyz[2][i] + SCALE / 2 + SCALE / 3) % SCALE] + SCALE) *
(BLUE_COLORS - 1) / SCALE / 2;
x += INCREMENT;
if (x >= SCALE)
x = -SCALE;
y += INCREMENT;
t_matrix++;
//void rotate(Int16 xyz[3][N], unsgined byte rgb[3][N],UInt16 angleX, UInt16 angleY, UInt16 angleZ)
static void rotate(int[][] xyz, byte[][] rgb, int angleX, int angleY, int angleZ)
UInt16 i;
int tmpX;
int tmpY;
UInt16 sinx = sine[angleX];
UInt16 cosx = cosi[angleX];
UInt16 siny = sine[angleY];
UInt16 cosy = cosi[angleY];
UInt16 sinz = sine[angleZ];
UInt16 cosz = cosi[angleZ];
tmpX = (xyz[0][i] * cosx - xyz[2][i] * sinx) / SCALE;
xyz[2][i] = (xyz[0][i] * sinx + xyz[2][i] * cosx) / SCALE;
xyz[0][i] = tmpX;
tmpY = (xyz[1][i] * cosy - xyz[2][i] * siny) / SCALE;
xyz[2][i] = (xyz[1][i] * siny + xyz[2][i] * cosy) / SCALE;
xyz[1][i] = tmpY;
tmpX = (xyz[0][i] * cosz - xyz[1][i] * sinz) / SCALE;
xyz[1][i] = (xyz[0][i] * sinz + xyz[1][i] * cosz) / SCALE;
xyz[0][i] = tmpX;
static int []oldProjX=new int[N];
static int []oldProjY=new int[N];
static int []oldDotSize=new int[N];
//void draw(int16_t xyz[3][N], uint8_t rgb[3][N])
static void draw(int[][] xyz, byte[][] rgb)
//static uint16_t oldProjX[N] = {0};
//static uint16_t oldProjY[N] = {0};
//static uint8_t oldDotSize[N] = {0};
int i;
int projX;
int projY;
int projZ;
int dotSize;
projZ = SCALE - (xyz[2][i] + SCALE) / 4;
projX = WINDOWX / 2 + (xyz[0][i] * projZ / SCALE) / 25;
projY = WINDOWY / 2 + (xyz[1][i] * projZ / SCALE) / 25;
dotSize = 3 - (xyz[2][i] + SCALE) * 2 / SCALE;
//swim_set_pen_color(&win1, 0);
//swim_put_circle(&win1, oldProjX[i], oldProjY[i], oldDotSize[i], 1);
LCD.DrawEllipse(Microsoft.SPOT.Presentation.Media.Color.Black, oldProjX[i], oldProjY[i], oldDotSize[i], oldDotSize[i]);
if (projX > dotSize &&
projY > dotSize &&
projX < WINDOWX - dotSize &&
projY < WINDOWY - dotSize)
swim_set_pen_color(&win1, (rgb[0][i] << REDSHIFT) +
(rgb[1][i] << GREENSHIFT) +
(rgb[2][i] << BLUESHIFT));
swim_put_circle(&win1, projX, projY, dotSize, 1);
LCD.DrawEllipse(Microsoft.SPOT.Presentation.Media.Color.White, projX, projY, dotSize, dotSize);
//LCD.Flush();
oldProjX[i] = projX;
oldProjY[i] = projY;
oldDotSize[i] = dotSize;
initialize();
int[][] xyz = new int[3][];
byte[][] rgb = new byte[3][];
int angleX = 0;
int angleY = 0;
int angleZ = 0;
int speedX = 0;
int speedY = 0;
int speedZ = 0;
xyz[0] = new int[N];
xyz[1] = new int[N];
xyz[2] = new int[N];
rgb[0] = new byte[N];
rgb[1] = new byte[N];
rgb[2] = new byte[N];
matrix(xyz, rgb);
rotate(xyz, rgb, angleX, angleY, angleZ);
draw(xyz, rgb);
speedZ -= SPEED;
if(joyState & JOYSTICK_RIGHT)
speedX -= SPEED;
else if(joyState & JOYSTICK_LEFT)
speedX += SPEED;
else if(joyState & JOYSTICK_UP)
speedY -= SPEED;
else if(joyState & JOYSTICK_DOWN)
speedY += SPEED;
else if(ledState & KEY1)
speedZ -= SPEED;
else if(ledState & KEY2)
speedZ += SPEED;
else if(ledState & KEY3) {
speedX = 0;
speedY = 0;
speedZ = 0;
angleX = 0;
angleY = 0;
angleZ = 0;
} else {
if(speedX > 0)
speedX -= SPEED;
else if(speedX < 0)
speedX += SPEED;
if(speedY > 0)
speedY -= SPEED;
else if(speedY < 0)
speedY += SPEED;
if(speedZ > 0)
speedZ -= SPEED;
else if(speedZ < 0)
speedZ += SPEED;
angleX += speedX;
angleY += speedY;
angleZ += speedZ;
if(angleX >= SCALE)
angleX -= SCALE;
else if(angleX < 0)
angleX += SCALE;
if(angleY >= SCALE)
angleY -= SCALE;
else if(angleY < 0)
angleY += SCALE;
if(angleZ >= SCALE)
angleZ -= SCALE;
else if(angleZ < 0)
angleZ += SCALE;
LCD.Flush();
System.Threading.Thread.Sleep(10);
