Certificate store and private key protection
Hello,
Is there a secure implementation of the certificate store from GHI ? Maybe more important, is there a secure implementation of a private key store ?
By secure I mean access protected by password and directory encrypted against reverse engineering or things like that (disassembling, …). Is GHIElectronics.NETMF.Hardware.Configuration.TinyBooter.DisableApplicationAccess protecting the stores ?
Thanks for your answers
Lionel
Yes, that method will completely lockout your software.
Now, remember that is impossible to make something 100% secure, on these devices or anything out there. GHI provides no guarantees but we did our best to test it out.
Hello Gus, thanks for your answer,
Related to this question, I wonder if DisableApplicationAccess can be disabled to do a software update ?
You are expected to have your own in-field update method, which should be encrypted and secure to fit your needs. Like customer updating the firmware from a USB memory stick or directly from your website.
Ok thank you for the answer Gus
Best regards
Lionel
