Hello,
I am new to .NETMF , i have try to react to an input button with the simple code
try
Debug.Print("Create Input BT Port");
bt = new InputPort(GHI.Hardware.FEZCerb.Pin.PC0, false, Port.ResistorMode.PullUp);
Debug.Print("Register BT Interrupt");
bt.OnInterrupt += bt_OnInterrupt;
Debug.Print("Enable BT Interrupt");
bt.EnableInterrupt();
catch (Exception ex)
Debug.Print("Cant setup BT " + ex.Message);
void bt_OnInterrupt(uint data1, uint data2, DateTime time)
Debug.Print("Button press");
I have try both Console Project or Gadgeteer but it fails with the follwing exception when adding the interrupt Handler:
Using mainboard GHI Electronics FEZCerbuinoBee version 1.2
Program Started
Une exception de première chance de type ‘System.InvalidOperationException’ s’est produite dans Microsoft.SPOT.Hardware.dll
Cant setup BT Exception was thrown: System.InvalidOperationException
the board is loaded with the last firmware 4.2.5 ethernet and have and ENC28 1.1
connected and pingable.
I also try other pin (PC1 PA4 ) without success
