Hello,
I´m new in this, my first question is, is possible use the usb Client like a virtual com in cerbuinobee?
I try to install the CDC_driver and doesn´t work, like explain in “https://www.ghielectronics.com/docs/20/usb-client”.
Hello,
You need to switch debugging to the serial port to do that, which is not possible on the cerb boards. You will need one of the other boards.
Ok. And is possible use on the usb host? Or the only way is use the uart port?
You can add a usb to serial converter and then use any of the serial ports
Ok. Tanks
is possible with the USB host make a connection with the pc and send and receive messages? on cerbuino bee?
like making the pc one usb client.
