Is there a way to detect when an SD card has been ejected with the built in SD card on the Cerbuino bee?
I tried the RemovableMedia.Eject event but that is not called.
I did not find any direct way so I tried to detect it in a round about way.
My application is a simple serial port data logger and the user can remove the SD card at any time. I simply put a try block around
to detect if a card is prestent and then allow logging to start.
I was hoping to put a try block around the calls to writing to the SD card that would catch an exception if the crad was removed while writing. Unfortunatley, that seems to crash the program and not catch the exception at all. Here is some test code. It tries to write every 5 seconds. After a successfull write I remove the card. The program just crashes without throwing any exception to the Output window
```cs
using System.Collections;
using Microsoft.SPOT.Touch;
using Microsoft.SPOT.IO;
using GHI.OSHW.Hardware;
using Gadgeteer.Networking;
using GT = Gadgeteer;
using System.IO.Ports;
using System.IO;
namespace LIN_Logger_Cerbuino
public partial class Program
SerialPort ComPort;
private GT.Timer _timer;
private string _root;
private bool _SDMounted = false;
timer.Tick +=<tab><tab>
timer.Start();
RemovableMedia.Eject +=new EjectEventHandler(RemovableMedia_Eject);
RemovableMedia.Insert+=new InsertEventHandler(RemovableMedia_Insert);
_timer = new GT.Timer(5000);
_timer.Tick += new GT.Timer.TickEventHandler(TimerTick);
_timer.Start();
void RemovableMedia_Insert(object sender, MediaEventArgs e)
Debug.Print("SD card inserted");
void RemovableMedia_Eject(object sender, MediaEventArgs e)
Debug.Print("SD card ejected");
private bool MountSD()
if (_SDMounted)
return true;
try
GHI.OSHW.Hardware.StorageDev.MountSD();
_SDMounted = true;
catch
Debug.Print("No SD Card");
_SDMounted = false;
return false;
try
if (VolumeInfo.GetVolumes()[0].IsFormatted)
_root = VolumeInfo.GetVolumes()[0].RootDirectory;
catch
_SDMounted = false;
return _SDMounted;
void TimerTick(GT.Timer timer)
Debug.Print("Tic Toc");
Stream stream;
if (MountSD())
Debug.Print("Have SD Card");
string fileName = Path.Combine(_root, "file.txt");
try
Debug.Print("Got Root");
if (File.Exists(fileName))
stream = File.OpenWrite(fileName);
stream.Position = stream.Length;
stream = File.Create(fileName);
using (var writer = new StreamWriter(stream))
writer.WriteLine(Guid.NewGuid().ToString());
stream.Dispose();
catch
Debug.Print("Failed to Write File");
_SDMounted = false;
