Cerbuino IO - which is which?
I am still using the STM32F405 with the Cerbuino for small one off projects but I have a question on the IO ports shown in the schematic for the Cerbuino Bee. I need clarification on which pins the functions appear as there is 2 for some functions.
PA6 shows SPI1_MISO and so does PB4. Which is the correct one? I am guessing PB4 as that is routed to X1
PB6 shows I2C-SCL, PB7 shows I2C-SDA and so does PB10 and PB11. Which is the correct one? I assume PB6 as this is routed to X2.
Which pins does the CAN bus appear one?
Which pins for SPI2?
STM chips are awesome in mapping functions to different pins. To know which pins are the ones we used in the old firmware you need to flip a coin :slight_smile: But here is a better idea. I am guessing the team has used the same pins on TinyCLR so take a look here TinyCLR-Ports/Device.h at dev · ghi-electronics/TinyCLR-Ports · GitHub
Good point Gus. I think you might be right as I saw something about this before. Didn’t think to check this.
The SMT chips are ace and the Cerbuino design is great for quick projects.
Thay are not the same :yum:
Anyone have the information at hand?
:sob:
#define STM32F4_ADC 1 // A6,A2,A3,C0,C1,A4,C2,C3,A5,B0,B1
#define STM32F4_AD_CHANNELS { 6, 2, 3,10,11, 4,12,13, 5, 8, 9}
// C6,A7,C7,A8,B0,B1,B5,B4,B3,B11,B10,A10,A9,A15, B8, B9
#define STM32F4_PWM_TIMER { 8,14, 8, 1, 3, 3, 3, 3, 2, 2, 2, 1, 1, 2, 4, 4}
#define STM32F4_PWM_CHNL { 0, 0, 1, 0, 2, 3, 1, 0, 1, 3, 2, 2, 1, 0, 2, 3}
#define STM32F4_PWM_PINS {38, 7,39, 8,16,17,21,20,19, 27, 26, 10, 9, 15, 24, 25}
#define STM32F4_SPI_SCLK_PINS {19} // PB3
#define STM32F4_SPI_MISO_PINS {20} // PB4
#define STM32F4_SPI_MOSI_PINS {21} // PB5
#define STM32F4_I2C_PORT 1
#define STM32F4_I2C_SCL_PIN 22 // PB6
#define STM32F4_I2C_SDA_PIN 23 // PB7
#define STM32F4_UART_RXD_PINS {39, 3, 27} // C7, A3, B11
#define STM32F4_UART_TXD_PINS {38, 2, 26} // C6, A2, B10
#define STM32F4_UART_CTS_PINS {109, 0, 29} // G13, A0, B13
#define STM32F4_UART_RTS_PINS {108, 1, 30} // G12, A1, B14
