I have a function that sends some data to a webserver.
The function works well when the server is online. But when the server is offline for some reason the controller hangs.
I hade the same problem with the panda II
Using .net 4.2
try catch doesn’t work.
the problem starts in line
Stream dataStream = request.GetRequestStream();
After a while I get an out of memory.Failed allocation for 514 blocks, 6168 bytes
request.timeout = x; doesn’t help
request.readwrite = x; doesn’t help
I used also some examples from codeshare but they have all the same result.
// Create a request using a URL that can receive a post.
WebRequest request = WebRequest.Create(_ClubInterfacePath);
// Set the Method property of the request to POST.
request.Method = "POST";
// Create POST data and convert it to a byte array.
string postData = "<clubrequest token=\"" + _Token + "\" " + Xml + " />"; ;
byte[] byteArray = Encoding.UTF8.GetBytes(postData);
// Set the ContentType property of the WebRequest.
request.ContentType = "application/x-www-form-urlencoded";
// Set the ContentLength property of the WebRequest.
request.ContentLength = byteArray.Length;
// Get the request stream.
// Write the data to the request stream.
dataStream.Write(byteArray, 0, byteArray.Length);
// Close the Stream object.
dataStream.Close();
// Get the response.
WebResponse response = request.GetResponse();
// Display the status.
Debug.Print(((HttpWebResponse)response).StatusDescription);
// Get the stream containing content returned by the server.
dataStream = response.GetResponseStream();
// Open the stream using a StreamReader for easy access.
StreamReader reader = new StreamReader(dataStream);
// Read the content.
string responseFromServer = reader.ReadToEnd();
// Display the content.
// Clean up the streams.
reader.Close();
dataStream.Close();
response.Close();
return responseFromServer;
Assembly: mscorlib (4.2.0.0) Assembly: Microsoft.SPOT.Native (4.2.0.0) Assembly: Microsoft.SPOT.Hardware (4.2.0.0)
Assembly: Microsoft.SPOT.Graphics (4.2.0.0) Assembly: Microsoft.SPOT.TinyCore (4.2.0.0)
Assembly: Microsoft.SPOT.Hardware.SerialPort (4.2.0.0) Assembly: Microsoft.SPOT.IO (4.2.0.0)
Assembly: System.IO (4.2.0.0) Assembly: Microsoft.SPOT.Hardware.OneWire (4.2.0.0)
Assembly: Microsoft.SPOT.Hardware.Usb (4.2.0.0) Assembly: Microsoft.SPOT.Hardware.PWM (4.2.0.1)
Assembly: Microsoft.SPOT.Net (4.2.0.0) Assembly: System (4.2.0.0) Loading Deployment Assemblies.
Assembly: GHIElectronics.Gadgeteer.FEZCerbuinoBee (1.1.1.0) Attaching deployed file.
Assembly: Gadgeteer (2.42.0.0) Attaching deployed file.
Assembly: Gadgeteer.WebClient (2.42.0.0) Attaching deployed file.
Assembly: Microsoft.SPOT.Net.Security (4.2.0.0) Attaching deployed file.
Assembly: GHI.OSHW.Hardware (4.2.3.1) Attaching deployed file.
Assembly: System.Http (4.2.0.0) Attaching deployed file.
Assembly: GadgeteerApp1 (1.0.0.0) Attaching deployed file.
Assembly: System.Net.Security (4.2.0.0) Resolving.
Ready.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\mscorlib.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Native.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Hardware.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Graphics.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.TinyCore.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Hardware.SerialPort.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.IO.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\System.IO.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Hardware.OneWire.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Hardware.Usb.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Hardware.PWM.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Net.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\System.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Gadgeteer\Core\Assemblies.NET Micro Framework 4.2\le\Gadgeteer.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics\GHI OSHW NETMF v4.2 SDK\Assemblies\le\GHI.OSHW.Hardware.dll’
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics\GHI .NET Gadgeteer SDK\Mainboards\FEZCerbuinoBee\NETMF 4.2\le\GHIElectronics.Gadgeteer.FEZCerbuinoBee.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Net.Security.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\System.Net.Security.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\System.Http.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Gadgeteer\Core\Assemblies.NET Micro Framework 4.2\le\Gadgeteer.WebClient.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘O:\FEZ\Cerberus Cerbuino Bee\MyFirstApp\GadgeteerApp1\bin\Debug\le\GadgeteerApp1.exe’, Symbols loaded.
Using mainboard GHI Electronics FEZCerbuinoBee version 1.2
Program Started
Initializing network…
Waiting for an IP Address…
IP Address: xxxxxxxxxx
Step into: Stepping over non-user code ‘System.Net.HttpWebRequest.GetRequestStream’
Step into: Stepping over non-user code ‘System.Net.HttpWebRequest.ValidateGetRequestStream’
Step into: Stepping over non-user code ‘System.Net.HttpWebRequest.TransferEncoding.get’
Step into: Stepping over non-user code ‘System.Net.WebHeaderCollection.this[string].get’
Step into: Stepping over non-user code ‘System.Net.HeaderValueCollection.GetValuePair’
Step into: Stepping over non-user code ‘System.Collections.ArrayList.Count.get’
Step into: Stepping over non-user code ‘System.Net.HttpWebRequest.ContentLength.get’
Step into: Stepping over non-user code ‘System.Net.HttpWebRequest.SubmitRequest’
Step into: Stepping over non-user code ‘System.Net.HttpWebRequest.EstablishConnection’
Step into: Stepping over non-user code ‘System.Uri.Host.get’
Step into: Stepping over non-user code ‘System.Uri.Port.get’
Step into: Stepping over non-user code ‘string.Concat’
Step into: Stepping over non-user code ‘string.ToString’
Step into: Stepping over non-user code ‘int.ToString’
Step into: Stepping over non-user code ‘System.Globalization.NumberFormatInfo.CurrentInfo.get’
Step into: Stepping over non-user code ‘System.Globalization.CultureInfo.CurrentUICulture.get’
Step into: Stepping over non-user code ‘System.Globalization.CultureInfo.NumberFormat.get’
Step into: Stepping over non-user code ‘System.Number.Format’
Step into: Stepping over non-user code ‘System.Number.ValidateFormat’
Step into: Stepping over non-user code ‘System.Number.PostProcessInteger’
Step into: Stepping over non-user code ‘System.Number.ReplaceNegativeSign’
Step into: Stepping over non-user code ‘System.Collections.ArrayList.ArrayList’
Step into: Stepping over non-user code ‘System.Uri.HostNameType.get’
Step into: Stepping over non-user code ‘System.Net.IPAddress.Parse’
Step into: Stepping over non-user code ‘System.Net.IPAddress.ConvertStringToInt32’
Step into: Stepping over non-user code ‘System.Net.IPAddress.IPAddress’
Step into: Stepping over non-user code ‘System.Net.Sockets.Socket.Socket’
Step into: Stepping over non-user code ‘System.Net.Sockets.Socket.SetSocketOption’
Step into: Stepping over non-user code ‘System.Net.IPEndPoint.IPEndPoint’
Step into: Stepping over non-user code ‘System.Net.EndPoint.EndPoint’
Step into: Stepping over non-user code ‘System.Net.Sockets.Socket.Connect’
Step into: Stepping over non-user code ‘System.Net.IPEndPoint.Serialize’
Step into: Stepping over non-user code ‘System.Net.SocketAddress.SocketAddress’
Step into: Stepping over non-user code ‘Microsoft.SPOT.Debug.Assert’
Step into: Stepping over non-user code ‘System.Net.Sockets.Socket.Poll’
