NETMF : V4.3 Firmware : V4.3.6 TinyCLR :V4.3.6
-I can get a good communication between the two Xbee ( XCTU Terminals) , Xbee mounted on Droids usb adaptators .
-With one Xbee on droids and one Xbee on Cerbuino ( result on VS2012 Debug Window) , all received chars are not recognisable , most of them are 0x0E
-Direct cabling RX to TX on the cerbuino Xbee pins , COM is good : Cerbuino understand itself
-direct cabling an FTDI adaptator on the TX/RX and using TERATERM gives the same result
I think there is a bug in the firmware that makes unworked COM to outside modules ( i didn’t try the Gadgeteer sockets) from the XBEE Pins on the Cerbuino .
Have you a solution to solve this problem ? return to old version of all ( NETMF / firmware / Tiny CLR) or putting my 2 Cerbuino in the garbage and buy another sbc ?
But the data Cerb to Cerb is garbled?
Try the following:
[ul]Run the serial ports dead slow 2400bps[/ul]
[ul]Connect Cerb to Cerb and verify they talk to each other[/ul]
[ul]Are you using the RTS and CTS pins? You should be. Serial is a very unreliable communication system (dispite what others here may thing, SPI is king in my book)[/ul]
[ul]Can you verify that the Xbee are talking to each other?[/ul]
[ul]Do you have a logic analzer to verify that the cables or crosstalk is not the problem[/ul]
[ul]If you suspect crosstalk, try to avoid sending and receiving at the same time[/ul]
I used a Bluetooth Bee Module as well as RN-XV WiFi Module on the XBee Socket of cerbuino Bee. Both worked without problems. Hardware-FlowControl however is not supported on the XBee Socket of Cerbuino Bee (only on Gadgeteer Socket 2). The lack of Hardware-Flowcontrol should not be a problem if the baudrate is not to high (at least not below 115200 Bits/sec). However there is a known issue on the Cerbuino Bee with the serial port when additionally SPI (e.g. ENC 28 Ethernet) is used at the same time.
many thanks for your response , John Smith and Roschemi ; i tried yours ideas , but the problem is still here :
-connecting my 2 Cerbuino with cross wires (RX TX) and visalising the result on VS2012 debug window =That's OK , the txo SBC can discuss themselves without errors
-fall down the baudrate to 2400 and less , the result is always bad ,
I join a drawing of the tests i’ve made , i hope it 'll be comprhensible .
using System.Collections;
using System.IO;
using System.IO.Ports;
using System.Text;
using Microsoft.SPOT.IO;
using Microsoft.SPOT.Touch;
using Gadgeteer;
using Gadgeteer.Networking;
using GT = Gadgeteer;
//using GHI.Hardware;
//using GHI.Hardware.FEZCerb;
using GHIElectronics.Gadgeteer;
namespace GadgeteerApp8
public partial class Program
bool Is_LED_On = false;
public static SerialPort Xbee = null;
OK , i red the error : 57600 instead 9600 ; as the program is the same for the 2 Cerbuino , they can exhange with no errors and as i thought i’ve programmed 9600 , it 's normal that the two tests noted as “BAD” don’t work.because Teraterm was 9600 .
I’m very confuse ,but i’ve encountered other problems before this code bigan to work and i don’t read and read again my code .
I try this way tomorow .
So i’m “Newbie” , i will encounter some other situations that makes you an indispensable support .
