Hi !!
I start to use my Cerbuino bee. I Upgrade de firmare.
Than I create a new project with a button and a ldr7r and everything is ok, but when i try to add a seed oled i have several probllems:
- First toolbox Seed Tab doens't appear. I try to show all tabs, but seed tab is in Gray.
- I add a reference directly to my project and the project start to give some errors.
Assembly: GTM.Seeed.OledDisplay (1.4.1.0) needs assembly 'Gadgeteer' (2.41.0.0)
Assembly: GTM.Seeed.OledDisplay (1.4.1.0) needs assembly 'mscorlib' (4.1.2821.0)
Assembly: GTM.Seeed.OledDisplay (1.4.1.0) needs assembly 'Microsoft.SPOT.Graphics' (4.1.2821.0)
Error: a3000000
Cerbuino MsDeploy info :
Pinging… TinyCLR
DeviceInfo:
HAL build info: 4.2.0.0, Copyright Oberon microsystems, Inc.
OEM Product codes (vendor, model, SKU): 255, 0, 65535
Serial Numbers (module, system):
FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
Solution Build Info: 4.2.1.0, Copyright (C) GHI Electronics, LLC
AppDomains:
default, id=1
Assemblies:
mscorlib,4.2.0.0
Microsoft.SPOT.Native,4.2.0.0
Microsoft.SPOT.Hardware,4.2.0.0
Microsoft.SPOT.Graphics,4.2.0.0
Microsoft.SPOT.TinyCore,4.2.0.0
Microsoft.SPOT.Hardware.SerialPort,4.2.0.0
Microsoft.SPOT.Hardware.OneWire,4.2.0.0
Microsoft.SPOT.Hardware.Usb,4.2.0.0
Microsoft.SPOT.Hardware.PWM,4.2.0.1
Microsoft.SPOT.Net,4.2.0.0
System,4.2.0.0
GHIElectronics.Gadgeteer.FEZCerbuinoBee,1.0.1.0
Gadgeteer,2.42.0.0
Gadgeteer.WebClient,2.42.0.0
GTM.Seeed.OledDisplay,1.4.1.0
Microsoft.SPOT.IO,4.2.0.0
GTM.GHIElectronics.LED7R,1.0.0.0
Gadgeteer.SPI,2.42.0.0
Microsoft.SPOT.Touch,4.2.0.0
System.Http,4.2.0.0
GHI.OSHW.Hardware,4.2.1.0
GTM.GHIElectronics.Button,1.0.0.0
System.IO,4.2.0.0
GadgeteerApp3,1.0.0.0
Gadgeteer.WebServer,2.42.0.0
Microsoft.SPOT.Net.Security,4.2.0.0
System.Net.Security,4.2.0.0
COMPILE ERROS WHEN COMPILE WITH SEEED OLED DISPLAY
Create TS.
Loading start at 8055f8c, end 8079ab0
Assembly: mscorlib (4.2.0.0)Assembly: Microsoft.SPOT.Native (4.2.0.0)Assembly: Microsoft.SPOT.Hardware (4.2.0.0)
Assembly: Microsoft.SPOT.Graphics (4.2.0.0)Assembly: Microsoft.SPOT.TinyCore (4.2.0.0)
Assembly: Microsoft.SPOT.Hardware.SerialPort (4.2.0.0)Assembly: Microsoft.SPOT.Hardware.OneWire (4.2.0.0)
Assembly: Microsoft.SPOT.Hardware.Usb (4.2.0.0)Assembly: Microsoft.SPOT.Hardware.PWM (4.2.0.1)
Assembly: Microsoft.SPOT.Net (4.2.0.0)Assembly: System (4.2.0.0)Loading Deployment Assemblies.
Attaching deployed file.
Assembly: GHIElectronics.Gadgeteer.FEZCerbuinoBee (1.0.1.0)Attaching deployed file.
Assembly: Gadgeteer (2.42.0.0)Attaching deployed file.
Assembly: GTM.Seeed.OledDisplay (1.4.1.0)Attaching deployed file.
Assembly: Microsoft.SPOT.IO (4.2.0.0)Attaching deployed file.
Assembly: GTM.GHIElectronics.LED7R (1.0.0.0)Attaching deployed file.
Assembly: Microsoft.SPOT.Touch (4.2.0.0)Attaching deployed file.
Assembly: System.Http (4.2.0.0)Attaching deployed file.
Assembly: GHI.OSHW.Hardware (4.2.1.0)Attaching deployed file.
Assembly: GTM.GHIElectronics.Button (1.0.0.0)Attaching deployed file.
Assembly: System.IO (4.2.0.0)Attaching deployed file.
Assembly: GadgeteerApp4 (1.0.0.0)Attaching deployed file.
Assembly: System.Net.Security (4.2.0.0)Attaching deployed file.
Assembly: Microsoft.SPOT.Net.Security (4.2.0.0)Resolving.
Assembly: GTM.Seeed.OledDisplay (1.4.1.0) needs assembly ‘Gadgeteer’ (2.41.0.0)
Assembly: GTM.Seeed.OledDisplay (1.4.1.0) needs assembly ‘mscorlib’ (4.1.2821.0)
Assembly: GTM.Seeed.OledDisplay (1.4.1.0) needs assembly ‘Microsoft.SPOT.Graphics’ (4.1.2821.0)
Error: a3000000
Waiting for debug commands…
The program ‘[5] Micro Framework application: Managed’ has exited with code 0 (0x0).
Any help ??
Thanks in advance !
