I have just been given a Cerbuino Bee for Christmas. When I first tried it on my laptop, prior to attempting to update the firmware, I ran MF Deploy and the Bee was listed under the USB Device drop-down and all appeared to work fine. However, after (I believe successfully) loading TinyBooter using STDFU Tester and pressing the reset button as per the online tutorial, the Bee was no longer listed in the USB Device drop-down menu in MF Deploy, suggesting that it was not recognised by my laptop. Thereafter, I attempted to update the USB driver without success. I subsequently tried the Bee on another computer and, having installed the USB driver when prompted after plugging the Bee in, it was successfully recognised in MF Deploy and under Device Manager. Thereafter, I updated the TinyCLR firmware on the Bee using this second computer and all seems fine.
Going back to my original laptop, the Bee is still not recognised, so I am currently thinking that I may have a USB driver issue here. When plugging in the Bee, it pops up under âUniversal Serial Bus Controllersâ as âGHI NETMF Debug Interfaceâ and claims to be working properly. It is also worth mentioning that when I plug in my (working) Domino board to this laptop, the Domino appears under âDebuggable .Net Micro Framework Deviceâ as âGHI.NET Micro Framework USB Debugging Interfaceâ, rather than under âUniversal Serial Bus Controllersâ. If I attempt to update the Beeâs driver software in Device Manager, I just get âWindows has determined the driver software for your device is up to dateâ.
Could anyone please help?
Many thanks
Ian.
