baz
1
Hello,
I’ve a cerbuino with a problem reading analog input.
I’m using a
Private _adc As Microsoft.SPOT.Hardware.AnalogInput
to read data.
I’ve a pin connected to a sensor, that seems ok. All other pins are free. But
_adc.ReadRaw
reports something through 200 and 600… why?
Is it better to use ReadRaw or Read to sample an analog sensor?
thanks
did you specify which pin?
such as _adc = new AnalogInput(FEZCerbuino.Pin.AnalogIn.A0);
baz
3
sure:
Hardware.Cpu.Pin.GPIO_Pin10
for the pin A0 (where I’ve the sensor connected)
and
Hardware.Cpu.Pin.GPIO_Pin8
for the pin A1 (currently not connected)
readraw returns the raw ad 0-1023. where
0= 0 volts
1023=3.3 volts
so if you want the voltage you need to divide the returned value by 310
baz
5
Ehm, how did I explain this reading?
? _adc.ReadRaw
2945
sorry about that it is 12 bit adc not 10 bit as i thought so the range is
0=0
4095=3.3 volts
so to get the voltage divide your value by 1240.9
baz
7
So, if my sensor measures a value between 0 and 12.7, the right formula to read it from cerbuino ADC, rounded to 2 decimal digits, is
Return System.Math.Round(cPrecision * (_adc.ReadRaw() * 12.7 / 4095) / cPrecision
thanks!
