@ njbuch - Can you post some code and any exception message and stack trace? The mainboard version string was not updated when we released a new version of the hardware, it is fixed for the next release.
I think I might experience a related or the same problem:
I have a FEZ Cerbot 1.3.
I can connect an accelerometer (G248) to socket 1 and 2.
However, if I connect a gyro (I have two brand new of these and tried both of them) alone or with other modules to socket 1 or 2 (which are the sockets indicated as valid choices by the designer view in VS) the is an Exception thrown (despite having no own code accessing the gyro at all - just the constructor call is enough).
Details:
System.Exception
Message is “Exception was thrown: System.Exception”
No inner exception.
Manually trying to create an instance of the Gyro class (with or without a physical device connected) always leads to an exception with a message explaining, that the socket must support type “I” but doesn’t.
I don’t know if this is correct, because I am a beginner.
But I now also tried to create an instance of the Gyro class without a physical device connected to the sockets 1 and 2. For me the exception looks just the same as if the gyro were connected.
Do I have a Gyro/drive related problem here?
I.e.: Should I better start a new thread for this problem?
@ F. Laskowski - You mention that you are using the FEZ Cerbot but that the designer shows sockets 1 and 2 as valid choices for the Gyro. Are you by any chance using the FEZ Cerberus mainboard in the designer? Because the FEZ Cerbot is not supported in the designer anymore.
I have the project, but I am not sure that is what you want. I can send an email with a project that does not work altough all specs tell me that it should…
@ njbuch - Sorry about that, I didn’t see your original post when I was replying. Just a minimal project that reliably reproduces the error is all I need. The source of the hall sensor would help too.
