Hi guys,
Yet another simple thing that I can’t seem to fix:
the code
if (sdCard.Mount())
Debug.Print("sd root dir: " + sdCard.StorageDevice.RootDirectory);
sdCard.Unmount();
Debug.Print("Failed to mount the SD card!");
the output
[quote]Using mainboard GHI Electronics FEZ Cerberus version 1.3
A first chance exception of type ‘System.Exception’ occurred in GHI.Hardware.dll
Failed to mount the SD card![/quote]
I’ve found a mix of examples, but something easy as mounting the SD card fails …
Any help would be much appreciated
@ thisway.ro - Can you verify that sdCard.IsCardInserted is true and that IsCardMounted is false? Can you try to format the card on your computer?
@ John - yes, IsCardInserted has the value 1 and IsCardMounted the value 0. I have formatted it as FAT without any different result
@ Dat - the connection is good
I have changed the code a bit, but no luck:
while (!sdCard.IsCardMounted)
Debug.Print("SD card not mounted yet ...");
sdCard.Mount();
Thread.Sleep(1000);
if (sdCard.IsCardMounted)
sdCard.Unmount();
[quote]A first chance exception of type ‘System.Exception’ occurred in GHI.Hardware.dll
SD card not mounted yet …
[/quote]
and this goes on forever …
@ thisway.ro -
Make new project, non-gadgeteer, deploy tiny code below, it can check what problem is.
using System.IO;
using Microsoft.SPOT.IO;
using GHI.IO;
using GHI.IO.Storage;
class Program
static SDCard sd_card = null;
static InputPort button = new InputPort((Cpu.Pin)xx, false, Port.ResistorMode.PullUp);
while (button.Read())
Thread.Sleep(100);
Debug.print("Wait for pressing the button");
sd_card = new SDCard();
// if exception here:
// + Check wire or connection
// + Try diffirent card.
sd_card.Mount();
// + reduce SD clock
// + Format FAT32 by PC
Debug.Print("SD Mounted");
