Before I dig into the code, has anyone successfully used Util.SetSpecialDisplayConfig to enable flushing of a bitmap to the N18 display connected to a Cerberus?
By allocating the bitmap early I am able to successfully allocate the full bitmap of 128*160 without memory issues. The problem is that when I flush the bitmap it seems that the data is corrupted, it looks like the center of the screen is considered 0, 0 and everything rendered is limited to the bottom right corner.
Here is the code I am testing with
Note: I have restricted the amount of the bitmap that is flushed so that the issue is visible. When flushing the full bitmap the same problem exists, but it wraps around and clears the ellipse.
using GHI.OSHW.Hardware;
using GT = Gadgeteer;
namespace TinkerKitGame
public partial class Program
// Allocate the bitmap early ensures that there is enough memory
private Bitmap _surface = new Bitmap(128, 160);
display_N18.Clear();
// SPI Configuration for socket 5
SPI.Configuration spi = new SPI.Configuration((Cpu.Pin)47, false, 0, 0, false, true, 12000, SPI.SPI_module.SPI1);
Util.SetSpecialDisplayConfig(spi, Util.BPP_Type.BPP16_BGR_LE);
// Draw on the bitmap
_surface.DrawRectangle(GT.Color.Red, 1, 0, 0, 160, 128, 0, 0, GT.Color.Red, 0, 0, GT.Color.Red, 0, 0, Bitmap.OpacityOpaque);
_surface.DrawEllipse(GT.Color.White, 25, 25, 20, 20);
// I have restricted the amount of the bitmap that is flushed so that the issue is visible.
// When flushing the full bitmap the same problem exists, but it wraps around and clears the ellipse.
//_surface.Flush();
_surface.Flush(0, 0, 128, 50);
