Just updated another Cerberus without problems, but this one are not willing to work with me. Followed the instructions on the Cerberus firmware update closely, but it returns an error after Erase->Go in STDFU Tester program.
@ Aron - Only this board. Updated another Cerberus 1 week ago on same machine. Have tried other ports and 1 other machine. This board is working fine without the tinybooter update it seems, and I have deployed new code to it, and updated tinyclr according to 2014R1 package.
Sorry if I am unclear. All points Jeff stated are correct.
For both CERB-A I have tried on two different machinces, both running windows 8.1 64-bit. CERB-B was successfully updated with one of these machines.
Maybe I should try updating CERB-B again, and see if the machines has been messed up, or its the board (which is the only thing that comes to my mind…).
Is this maybe a power level problem? I have more success these days with one of these ‘dual power USB’ cables.
It solved at least the problem that I needed to reconnect the board every second upload attempt. I can now upload my code numerous times without hardware errors.
From the sellers page:
It seems to improve my setup but I haven’t tested it thoroughly… just an idea.
@ Jeff - The two Cerberus boards that needs the update are in operation, and I didnt succeed in the available window of opportunity. I will of course let you know as soon as I get to them again.
