First time using this particular cerberus. So, I am going through the DFU stuff you have to do up front. But, the cerberus is not recognized over USB. It always comes up as “unknown device” on Windows 7 x64. I was able to update my Cerbuinos a few weeks ago from this same machine.
The USB Client SP 1.2 is the only thing plugged into it. I have it in socket 8. The red light on the board is lit, so it is getting power. The board is plugged into the same USB socket on a powered hub that I use for all my Gadgeteer work. I’ve tried two different gadgeteer cables.
I’ve uninstalled the “Unknown Device” from the Device Manager, but when redetected, it comes up as an unknown device with an error. I get the same thing whether I jump the boot pads with a wire or not.
In case it was a problem with the boot pads, I just now soldered a two pin header to them and jumped while plugging in. Still no go.
Is the cerberus DOA, or is there some mojo I can apply here?
Pete
