Hello All,
Just got my first Gadgeteer kit today (FEZ Cerberus) have set up the hardware and started trying the introductory exercise in the FEZCerberus Basic Kit Guide.pdf which involves toggling an LED on/off using the Joystick.
when I attempt to compile the code I receive the error message below.
Can anyone confirm that I need to update the firmware on my board (GHI Electronics – Where Hardware Meets Software)?
I am using a fresh install of Visual Studios 2010 and the latest version of the GHI NETMF v4.2 and Gadgeteer Package July 23rd which is found at this link: http://www.tinyclr.com/forum/topic?id=7982
Create TS.
Loading start at 8059dcc, end 807ac80
Assembly: mscorlib (4.2.0.0)Assembly: Microsoft.SPOT.Native (4.2.0.0)Assembly: Microsoft.SPOT.Hardware (4.2.0.0)
Assembly: Microsoft.SPOT.Graphics (4.2.0.0)Assembly: Microsoft.SPOT.TinyCore (4.2.0.0)
Assembly: Microsoft.SPOT.Hardware.SerialPort (4.2.0.0)Assembly: Microsoft.SPOT.Hardware.OneWire (4.2.0.0)
Assembly: Microsoft.SPOT.Hardware.Usb (4.2.0.0)Assembly: Microsoft.SPOT.Hardware.PWM (4.2.0.1)
Attaching deployed file.
Assembly: Microsoft.SPOT.IO (4.2.0.0)Attaching deployed file.
Assembly: GTM.GHIElectronics.Joystick (1.0.1.0)Attaching deployed file.
Assembly: Gadgeteer (2.42.0.0)Attaching deployed file.
Assembly: System.Http (4.2.0.0)Attaching deployed file.
Assembly: System (4.2.0.0)Attaching deployed file.
Assembly: Microsoft.SPOT.Net.Security (4.2.0.0)Attaching deployed file.
Assembly: GHIElectronics.Gadgeteer.FEZCerberus (1.0.5.0)Attaching deployed file.
Assembly: Lights (1.0.0.0)Attaching deployed file.
Assembly: Microsoft.SPOT.Touch (4.2.0.0)Attaching deployed file.
Assembly: GTM.GHIElectronics.LED7R (1.0.0.0)Attaching deployed file.
Assembly: GHI.OSHW.Hardware (4.2.2.0)***********************************************************************
ERROR!!! Firmware version does not match managed code version!!! *
Invalid native checksum: GHI.OSHW.Hardware 0x73150480!=0x52D307E9 *
Resolving.
Assembly: GTM.GHIElectronics.Joystick (1.0.1.0) needs assembly ‘Gadgeteer’ (2.42.0.0)
Assembly: Gadgeteer (2.42.0.0) needs assembly ‘Microsoft.SPOT.Net’ (4.2.0.0)
Assembly: Gadgeteer (2.42.0.0) needs assembly ‘System.IO’ (4.2.0.0)
Assembly: System.Http (4.2.0.0) needs assembly ‘System’ (4.2.0.0)
Assembly: System.Http (4.2.0.0) needs assembly ‘System.Net.Security’ (4.2.0.0)
Assembly: System (4.2.0.0) needs assembly ‘Microsoft.SPOT.Net’ (4.2.0.0)
Assembly: GHIElectronics.Gadgeteer.FEZCerberus (1.0.5.0) needs assembly ‘Gadgeteer’ (2.42.0.0)
Assembly: GHIElectronics.Gadgeteer.FEZCerberus (1.0.5.0) needs assembly ‘GHI.OSHW.Hardware’ (4.2.2.0)
Assembly: Lights (1.0.0.0) needs assembly ‘Gadgeteer’ (2.42.0.0)
Assembly: Lights (1.0.0.0) needs assembly ‘GTM.GHIElectronics.Joystick’ (1.0.1.0)
Assembly: Lights (1.0.0.0) needs assembly ‘GTM.GHIElectronics.LED7R’ (1.0.0.0)
Assembly: Lights (1.0.0.0) needs assembly ‘GHIElectronics.Gadgeteer.FEZCerberus’ (1.0.5.0)
Assembly: GTM.GHIElectronics.LED7R (1.0.0.0) needs assembly ‘Gadgeteer’ (2.42.0.0)
Error: a3000000
Waiting for debug commands…
The program ‘[1] Micro Framework application: Managed’ has exited with code 0 (0x0).
