Hi all,
I’m a new programmer on netmf but not new on .net. I want t thanks GHI innovation. The gadgeteer’s and ghi mainboard with their modules are a good issue for my developpement time.
on a project, I want to log informations on µSD. And this doesn’t work. I searched since days for a solution, in the forum and codeshare but no one samples work.
My sdcard is a kingston 4GB SDHC. Format in FAT32 / 4k per blocks.
The code :
using System.IO;
using Microsoft.SPOT.IO;
using GT = Gadgeteer;
namespace GadgeteerApp1
public partial class Program
private static string szTextContent = "If I told you, I'd have to kill you...\r\n";
DebugPrint("Program Started");
sdCard.DebugPrintEnabled = true;
sdCard.SDCardMounted += new GTM.GHIElectronics.SDCard.SDCardMountedEventHandler(sdCard_SDCardMounted);
sdCard.SDCardUnmounted += new GTM.GHIElectronics.SDCard.SDCardUnmountedEventHandler(sdCard_SDCardUnmounted);
Microsoft.SPOT.IO.RemovableMedia.Eject += new Microsoft.SPOT.IO.EjectEventHandler(RemovableMedia_Eject);
Microsoft.SPOT.IO.RemovableMedia.Insert += new Microsoft.SPOT.IO.InsertEventHandler(RemovableMedia_Insert);
void RemovableMedia_Insert(object sender, Microsoft.SPOT.IO.MediaEventArgs e)
DebugPrint("Insert - Mounted : " + e.Volume.Name);
void RemovableMedia_Eject(object sender, Microsoft.SPOT.IO.MediaEventArgs e)
DebugPrint("Eject - UnMounted : " + e.Volume.Name);
void sdCard_SDCardUnmounted(GTM.GHIElectronics.SDCard sender)
DebugPrint("SDCardUnmounted - Mounted : " + sender.IsCardMounted + ", Inserted : " + sender.IsCardInserted);
void sdCard_SDCardMounted(GTM.GHIElectronics.SDCard sender, GT.StorageDevice SDCard)
DebugPrint("SDCardMounted - Mounted : " + sender.IsCardMounted + ", Inserted : " + sender.IsCardInserted);
ShowDevInfo(SDCard);
Boolean Tests = RunBasicTests(SDCard.Volume);
DebugPrint("Basic storage tests " + ((Tests) ? "passed" : "failed"));
void ShowDevInfo(GT.StorageDevice StrgDev)
VolumeInfo VolInfo = StrgDev.Volume;
string DevInfo = VolInfo.Name + " format details:\r\n" +
"Device Flags = " + VolInfo.DeviceFlags + "\r\n" +
"FileSystem = " + VolInfo.FileSystem + "\r\n" +
"FileSystemFlags = " + VolInfo.FileSystemFlags + "\r\n" +
"SerialNumber = " + VolInfo.SerialNumber + "\r\n" +
"TotalFreeSpace = " + VolInfo.TotalFreeSpace + "\r\n" +
"TotalSize = " + VolInfo.TotalSize + "\r\n" +
"VolumeID = " + VolInfo.VolumeID + "\r\n" +
"VolumeLabel = " + VolInfo.VolumeLabel + "\r\n\r\n";
string DirInfo = "Dir of " + VolInfo.Name + "\r\n" +
StrgDev.RootDirectory + "\r\n";
string[] RootFiles = StrgDev.ListRootDirectoryFiles();
string Files = string.Empty;
foreach (string File in RootFiles)
FileInfo FileNfo = new FileInfo(StrgDev.RootDirectory + "\\" + File);
Files += (new string(' ', StrgDev.RootDirectory.Length) + File + " size: " + FileNfo.Length + " bytes\r\n");
DebugPrint(DevInfo + DirInfo + Files);
private Boolean RunBasicTests(VolumeInfo VolInfo)
if (!CreateDir(VolInfo.RootDirectory + "\\TestFolder"))
return false;
DebugPrint("CreateDir test passed");
if (!WriteTextFile(VolInfo.RootDirectory + "\\TestFolder\\TestFile.txt"))
return false;
DebugPrint("WriteTextFile test passed");
ShowTestResults(VolInfo);
if (!DeleteDir(VolInfo.RootDirectory + "\\TestFolder"))
return false;
DebugPrint("DeleteDir test passed");
VolInfo.FlushAll();
return true;
private Boolean CreateDir(string szFolderName)
DirectoryInfo Folder = new DirectoryInfo(szFolderName);
try
Folder.Create();
catch (Exception err)
DebugPrint("Failed to create " + szFolderName + "; " + err.Message);
return false;
DebugPrint("Created " + szFolderName);
return Folder.Exists;
private Boolean WriteTextFile(string szFileName)
StreamWriter Stream = GetFileStream(szFileName);
if (null == Stream)
return false;
try
Stream.Write(szTextContent);
Stream.Close();
DebugPrint("Failed to write " + szTextContent + " to " + szFileName + "; " + err.Message);
return false;
Stream.Close();
DebugPrint("Wrote " + szTextContent + " to " + szFileName);
return true;
private Boolean DeleteDir(string szFolderName)
try
Folder.Delete(true);
DebugPrint("Failed to delete " + szFolderName + "; " + err.Message);
return false;
DebugPrint("Deleted " + szFolderName);
return !Folder.Exists;
private StreamWriter GetFileStream(string szFileName)
StreamWriter Stream = null;
try
Stream = new StreamWriter(szFileName);
DebugPrint("Failed to access " + szFileName + "; " + err.Message);
return Stream;
void ShowTestResults(VolumeInfo VolInfo)
DirectoryInfo DirInfo = new DirectoryInfo(VolInfo.RootDirectory + "\\TestFolder");
FileInfo[] Files = DirInfo.GetFiles();
string FileData = string.Empty;
foreach (FileInfo File in Files)
FileData += (new string(' ', VolInfo.RootDirectory.Length) + File.Name + " size: " + File.Length + " bytes\r\n");
DebugPrint("** Contents of " + VolInfo.RootDirectory + "\\" + DirInfo.Name + "\r\n" + FileData);
void DebugPrint(string Msg)
Debug.Print("[" + DateTime.Now.ToString("hh:mm:ss.fff") + "] " + Msg);
and result in debug output
Create TS.
Loading start at 8059bec, end 8082120
Assembly: mscorlib (4.2.0.0)Assembly: Microsoft.SPOT.Native (4.2.0.0)Assembly: Microsoft.SPOT.Hardware (4.2.0.0)
Assembly: Microsoft.SPOT.Graphics (4.2.0.0)Assembly: Microsoft.SPOT.TinyCore (4.2.0.0)
Assembly: Microsoft.SPOT.Hardware.SerialPort (4.2.0.0)Assembly: Microsoft.SPOT.IO (4.2.0.0)
Assembly: System.IO (4.2.0.0)Assembly: Microsoft.SPOT.Hardware.OneWire (4.2.0.0)Assembly: Microsoft.SPOT.Hardware.Usb (4.2.0.0)
Assembly: Microsoft.SPOT.Hardware.PWM (4.2.0.1)Assembly: Microsoft.SPOT.Net (4.2.0.0)
Assembly: System (4.2.0.0)Loading Deployment Assemblies.
Attaching deployed file.
Assembly: GHI.OSHW.Hardware (4.2.2.0)Attaching deployed file.
Assembly: Gadgeteer (2.42.0.0)Attaching deployed file.
Assembly: System.Http (4.2.0.0)Attaching deployed file.
Assembly: GTM.GHIElectronics.SDCard (1.0.0.0)Attaching deployed file.
Assembly: Microsoft.SPOT.Net.Security (4.2.0.0)Attaching deployed file.
Assembly: GHIElectronics.Gadgeteer.FEZCerberus (1.0.5.0)Attaching deployed file.
Assembly: Microsoft.SPOT.Touch (4.2.0.0)Attaching deployed file.
Assembly: GadgeteerApp1 (1.0.0.0)Attaching deployed file.
Assembly: System.Net.Security (4.2.0.0)Resolving.
Ready.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managé) : 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\mscorlib.dll' chargé, symboles chargés.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managé) : 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Native.dll' chargé, symboles chargés.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managé) : 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Hardware.dll' chargé, symboles chargés.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managé) : 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Graphics.dll' chargé, symboles chargés.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managé) : 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.TinyCore.dll' chargé, symboles chargés.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managé) : 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Hardware.SerialPort.dll' chargé, symboles chargés.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managé) : 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.IO.dll' chargé, symboles chargés.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managé) : 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\System.IO.dll' chargé, symboles chargés.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managé) : 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Hardware.OneWire.dll' chargé, symboles chargés.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managé) : 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Hardware.Usb.dll' chargé, symboles chargés.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managé) : 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Hardware.PWM.dll' chargé, symboles chargés.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managé) : 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Net.dll' chargé, symboles chargés.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managé) : 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\System.dll' chargé, symboles chargés.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managé) : 'C:\Program Files (x86)\GHI Electronics\GHI OSHW NETMF v4.2 SDK\Assemblies\le\GHI.OSHW.Hardware.dll' chargé
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managé) : 'C:\Program Files (x86)\Microsoft .NET Gadgeteer\Core\Assemblies\.NET Micro Framework 4.2\le\Gadgeteer.dll' chargé, symboles chargés.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managé) : 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Net.Security.dll' chargé, symboles chargés.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managé) : 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\System.Net.Security.dll' chargé, symboles chargés.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managé) : 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\System.Http.dll' chargé, symboles chargés.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managé) : 'C:\Program Files (x86)\GHI Electronics\GHI .NET Gadgeteer SDK\Modules\SDCard\NETMF 4.2\le\GTM.GHIElectronics.SDCard.dll' chargé, symboles chargés.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managé) : 'C:\Program Files (x86)\GHI Electronics\GHI .NET Gadgeteer SDK\Mainboards\FEZCerberus\NETMF 4.2\le\GHIElectronics.Gadgeteer.FEZCerberus.dll' chargé, symboles chargés.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managé) : 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Touch.dll' chargé, symboles chargés.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managé) : 'C:\DocumentAllUsers\Programmation\Poubelle\GadgeteerApp1\GadgeteerApp1\bin\Debug\le\GadgeteerApp1.exe' chargé, symboles chargés.
Le thread '<Sans nom>' (0x2) s'est arrêté avec le code 0 (0x0).
Using mainboard GHI Electronics FEZCerberus version 1.1
SDCard ERROR : Unable to mount SD card. Is card formatted as FAT32?
[12:00:29.974] Program Started
[12:00:30.165] Eject - UnMounted : SD
[12:00:30.489] SDCardUnmounted - Mounted : True, Inserted : True
[12:00:31.170] Insert - Mounted : SD
[12:00:32.174] SDCardMounted - Mounted : True, Inserted : True
Le thread '<Sans nom>' (0x3) s'est arrêté avec le code 0 (0x0).
[12:00:41.501] SD format details:
Device Flags = 0
FileSystem = FAT
FileSystemFlags = 0
SerialNumber = 0
TotalFreeSpace = 3892305920
TotalSize = 3892314112
VolumeID = 0
VolumeLabel = NO NAME
Dir of SD
\SD
Une exception de première chance de type 'System.IO.IOException' s'est produite dans Microsoft.SPOT.IO.dll
[12:00:44.913] Failed to create \SD\TestFolder; Exception was thrown: System.IO.IOException
[12:00:45.603] Basic storage tests failed
Please help
