Hello, I am trying to get my head around RLP light on the Cerberus board. At the moment I simply want to call an RLP lite function that returns an integer, I will expand it once I get it going.
I am currently struggling to even get it running. In debug it hits the invoke line and then never returns. Can anyone see what I am doing wrong?
My C# code
using System.Collections;
using GHI.OSHW.Native;
using GHI.OSHW.Hardware.LowLevel;
namespace VGA_Cerb
public partial class Program
byte[] binfile = Resources.GetBytes(Resources.BinaryResources.RLPVGA);
AddressSpace.Write(0x2001A000, binfile, 0, binfile.Length);
RLPLite.Procedure RLP_VGAInit = new RLPLite.Procedure(0x2001a0bc);
byte[] b = new byte[1];
byte[] b2 = new byte[1];
int[] i = new int[1];
int boo = RLP_VGAInit.Invoke(new byte[0], new int[0], new byte[0]); //b, i, b2);
and my RLP, very simple
int notinit = 32;
int VGA_Init(void* par0, int* par1, unsigned char* par2)
int i = 32;
return i;
int main()
return 0;
I am using uVision4 with the following settings for the Cerb
R/O base: 0x3000
R/W base: 0x2001A000
Atmel AT91SAM9RL64
the address for the procedure from the map file is 0x2001a0bc (Same as the code above)
Can anyone see anything obvious? I have to reflash the Cerb after every boot so I am guessing its an address problem
Thanks for reading
Paul
