Is there a platform to make working with a device like this easier for a HW n00b?
By this I mean, the thought me of trying to solder wire/pins to the connections is very daunting. I can just see me putting a bit too much solder on one pin and it touching the adjoining pin and shorting something out.
Does anyone know if GHI plans on offering this device with the pins soldered on already (kinda like an arduino shield)?
It’s really nothing to be scared of. Just try it once and check your work before applying power If you really don’t want to go that far then you can always stick with the version with the plugs
Yes, the Cerberus (with sockets). That’s the whole idea behind this pair of boards. Prototype with the socketed version, then move to production with the cerb40. Software is exactly the same.
No, but I DO have a mostly-finished sprinkler controller that this will drop straight into, and the DIP40 form factor will make it MUCH simpler to wire up!
“Stacking” of shields is a nice concept, but in the real world, unless you have only one shield, you end up worrying about (and working around) a lot of pin overlap. The Gadgeteer solution of separate sockets is MUCH more capable.
It is refreshing to see someone with real-world experience. “Shield” is the coolest thing in my opinion, until you try to add more than one! 3 or more becomes impossible.
I think the idea is clear to almost everyone here. Want something super even fro software guys, Cerberus, want to get your soldering iron dirty, Cerb40. If you ask me, get both! I am sure you will use them both sooner or later.
Correct, more flexible = easier to use = more cost.
One option is to get cerberus + extender module. From there you can use breadboard to wire anything you like, including shield! Or you can use DuinoProto. The modules are there to make things awesome but they are not required.
