CERB40 || seems to crash again when upgrading from SDK version 4.3.7.9 (SDK 2015 prerelease) to version 4.3.7.10 (2015 Release)
After upgrading my device my code (which runs fine on 4.3.7.9) crashes after a few seconds. I was able to isolate the problem in the canbus SendMessage function which crashes the module after some successful sends.
Some remarks:
- Canbus runs fine when only receiving, though I receive from time to time a canbus 3 error
- When sending I get canbus 1 errors and the module crashes after some sends (from time to time SendMessage throws a System.Exception (stack trace NativeSendMessage)
- I did not find an explanation of the error codes 1 and 3 in the documentation
My test code
using GHI.Pins;
using GHI.IO;
namespace CanTest
static OutputPort LED; // led to check running
static bool sendCan = false;
static int cntr = 0;
private static void TimerTick100mS()
LED.Write((cntr++ % 5) == 0); // toggle led every 500 mSec
sendCan = true; // send message every 100 mSec
LED = new OutputPort(FEZCerb40II.Gpio.PB5, false);
var timer = new Timer(callback => TimerTick100mS(), null, 500, 100);
// Set some private timings and create canbus network
int PhaseSegment1 = 12;
int PhaseSegment2 = 8;
int BaudRatePrescaler = 4*16;
int propagation = 3;
var timings = new ControllerAreaNetwork.Timings(propagation, PhaseSegment1, PhaseSegment2, BaudRatePrescaler, 1, true);
var canChannel = new ControllerAreaNetwork(ControllerAreaNetwork.Channel.One, timings);
Byte[] outputData = new Byte[8];
// Handle error event
canChannel.ErrorReceived += (s, e) =>
Debug.Print("Error on CAN: " + e.Error.ToString());
s.Reset();
// Handle receiver event
canChannel.MessageAvailable += (s, e) =>
var m = s.ReadMessage();
try
var module = m. ArbitrationId >> 6;
var messageType = m.ArbitrationId & 0x1f;
Debug.Print("Message " + messageType.ToString() + " from " + module.ToString());
catch (Exception err)
Debug.Print("Error handling CAN message: " + err.ToString());
// enable controller
canChannel.Enabled = true;
if (sendCan)
sendCan = false;
// Create some message
uint moduleNr = 2;
uint messageID = (moduleNr << 6) + 1;
var message = new ControllerAreaNetwork.Message() { ArbitrationId = messageID, Length = 8, Data = new Byte[8], IsExtendedId = false, IsRemoteTransmissionRequest = false };
try
bool ok = canChannel.SendMessage(message); // Crashed Cerb40 after some successfull sends !!!
Debug.Print(ok ? "Send ok" : "Send NOK");
// From time to time we get a System.Exception ????
Debug.Print("Exception on sendmessage " + err.Message);
Thread.Sleep(10);
Debug output
Loading start at 8079dd4, end 809fd60
Assembly: mscorlib (4.3.1.0) Assembly: Microsoft.SPOT.Native (4.3.1.0) Assembly: Microsoft.SPOT.Hardware (4.3.1.0)
Assembly: Microsoft.SPOT.Graphics (4.3.1.0) Assembly: Microsoft.SPOT.TinyCore (4.3.1.0)
Assembly: Microsoft.SPOT.IO (4.3.1.0) Assembly: System.IO (4.3.1.0) Assembly: Microsoft.SPOT.Hardware.Usb (4.3.1.0)
Assembly: Microsoft.SPOT.Hardware.SerialPort (4.3.1.0) Assembly: Microsoft.SPOT.Hardware.PWM (4.3.1.0)
Attaching deployed file.
Assembly: CanTest (1.0.0.0) Attaching deployed file.
Assembly: GHI.Pins (4.3.7.10) Attaching deployed file.
Assembly: GHI.Hardware (4.3.7.10) Resolving.
Ready.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\mscorlib.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Native.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Graphics.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.TinyCore.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.IO.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\System.IO.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.Usb.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.SerialPort.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.PWM.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics\NETMF v4.3 SDK\Libraries\le\GHI.Hardware.dll’
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘c:\users\luc\documents\visual studio 2013\Projects\CanTest\CanTest\bin\Debug\le\CanTest.exe’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics\NETMF v4.3 SDK\Libraries\le\GHI.Pins.dll’
Send ok
Error on CAN: 1
Error on CAN: 1
Error on CAN: 1
Message 11 from 2
Message 11 from 2
Message 11 from 2
Message 11 from 2
Message 11 from 2
Message 11 from 2
Message 11 from 2
Message 11 from 2
Message 11 from 2
Message 11 from 2
Message 11 from 2
Message 11 from 2
Message 11 from 2
Send ok
Send ok
Send ok
Send ok
Error on CAN: 3
Error on CAN: 3
Message 11 from 2
Message 11 from 2
Message 11 from 2
Message 11 from 2
Message 11 from 2
Message 11 from 2
Message 11 from 2
Message 11 from 2
Message 11 from 2
Message 11 from 2
Message 11 from 2
Message 11 from 2
Message 11 from 2
Message 11 from 2
Send ok
Send ok
Send ok
Module crashes after some successful sends !!!
Is 4.3.7.10 behaving different ?
Is this a bug ? In error handling ?
Am I doing something wrong ?
Thx for help
