Hi, I have a Cerb 40 II with MF 4.3 and a N18 Display.
I need to knwon, how is the wiring? and how use some library (init, bitmap, pins)?
Thank you.
Thank you.
a Cerb40 is the same software wise as a Cerberus is, so you’d use the same code.
Wiring requires you to understand the S socket and the pinout of the N18. All that info is in the open source documents related to both those - check the catalog for schematics.
