You will draw about 400mA I think when you have both.
[/quote]
Thanks Gus – I’ll actually have a little more than plugged in
If my Gadgeteer is plugged into a vehicle and use 12V to USB adapter, would that be ample to power both? Or would you suggest something that would take the 12V and clean it up and then still use the plug?
I would expect that the current for a “standard” car 12v-to-USB adapter will NOT be sufficient. The USB spec says 500ma, but many converters I’ve seen are stable below 400ma and that last little bit is what usually brings devices unstuck if a device draws more current, as the voltage drops rapidly. As Gus says, try to let the DP module handle this problem, or only down-shift to say 7v but with something like a 1000ma capable circuit.
@ Gus - I have a FEZ Spider with Cellular Phone, GPS, T_35 screen and have connected to the power plug of the USB_ClientDP module a 7.4V Li-Ion battery. The board started regularly but after few minutes the USB module started to get warm and finally the red LED on the USB board and on the cellular phone blinked. End results: my Spider board is now not working anymore. Are you really sure that one can power these boards from a battery through the USB_ClientDP board??
The set worked correctly from the computer with the USB connection only.
@ Gus - LED on USBClientDP is blinking, no LED on Spider. The tensions on Pin 1 and 2 are correct (3.3V and 5V) when no Spider is attached. When the Spider board is attached, they are approximately 0-0.2 V. If I try to upload my program, it is not possible and I get following message
Deploy started: Project: GadgeteerApp1, Configuration: Debug Any CPU ------
Device not found or cannot be opened - USB:Gadgeteer========== Build: 1 succeeded, 0 failed, 0 up-to-date, 0 skipped ==========
========== Deploy: 0 succeeded, 1 failed, 0 skipped ==========
