Hello,
my recently arrived Cerberus is no longer recognized by my Windows 7
It was originally recognized by the OS. Having uninstalled everything GHI and Micro Framework, I installed the full Micro Framework and GHI 4.2 package as available from the support page. As I plugged the unit in, the āUSB Fez Cerberusā pop-op in the lower right corner came to. The unit was recognized by MSDeploy.exe and I could ping it.
However I could not deploy programs to it - I always got a āmscorlib version is 4.1 on your device but youāre trying to deploy a 4.2ā error message. So I experimented with changing the framework to 4.1, only to get an opposite āmscorlib version is 4.2 on your device but youāre trying to deploy a 4.1ā message. Frustrating. So I set out to update the firmware, as described on this page:
I installed the DfuSe_Demo_V3.0.2_Setup.exe. I set the BOOT pin high by sticking a paper-clip through the holes, similar to a piece of wire.
But when I plug the USB cable in, the unit is now no longer recognized. No lower-right corner USB notification. MSDeploy.exe cannot see the unit either, neither can the STDFU tester. And where before a green led lit up the board, now thereās but the sole red power ledā¦
How can I bring my Cerberus back to lifeā¦? I tried different USB ports and a different PC - no luck.
