Hi! I know this has been discussed, but I’ve not seen an answer that provides clear direction, so…
Where does one get the CDC VCOM drivers needed for using a FEZ Spider and USB DP Client as a CDC VCOM port? This is what my computer’s looking for:
USB\VID_1B9F&PID_F001&REV_0100
However, I have no .inf file that knows what driver to use. I’ve seen that the drivers are supposedly on my system, but would love to find the associated .inf.
Hi Gus, I’m sorry - I just can’t find that. The link you provided works clearly. (Thank you) But, I can’t find a document under the USB Client CDC page that points to it. Maybe I looked in the wrong place:
Is that needed? Or can I just put the .inf wherever convenient?
Also, I now see a com port for the CDC VCOM device. But, using putty (what a great program) I can’t open that serial port. I checked the speed, parity, bits, etc and that all matches. (I am successful in using putty for a BT SPP connection.
Sure. Downloaded ttperm23.zip, unzipped it and installed it. Changed the VCOM port to 2, since Tterm only works with ports 1-4 and 3&4 are already in use.
Same result: can’t open serial port.
A puzzler…
Oh - and now that I’ve installed the VCOM driver, the code thinks it’s connected and writes to the (non-existent) serial device (well, non-visible)
I’m traveling, but will download the (greatly) updated TTerm and try it as soon as I can. Like Dat, I see the device in the device manager as a CDC device, on whatever port. But, when I try to use a terminal program, it doesn’t hook up. Thanks for the new pointer, and I’ll let you know what happens!
Interesting. If I use the code sample, which merely streams a connected message, I can make that work. But, if I try the following:
int i = 0;
byte[] bytes = System.Text.Encoding.UTF8.GetBytes("Connected to FEZ Spider!" + i++.ToString() + "\r\n");
// Check if connected to PC
while (USBClientController.GetState() != USBClientController.State.Running)
debugLCD.Print("Waiting to connect to PC...");
Thread.Sleep(3000);
debugLCD.Print("Connected via CDC");
cdc.Write(bytes, 0, bytes.Length);
//break;
I see on my DebugLCD output that I am connected. However, I never get output in the serial terminal.
And, is there a way to know that someone has send data to the CDC port? That is, some callback like bt.DataReceived += new Bluetooth.DataReceivedHandler(bt_DataRcvd); for bluetooth?
