I create a CDC connection over USB (Vitual Comport) and sends data to a terminal program (as an example).
-> USBC_CDC cdc = USBClientController.StandardDevices.StartCDC();
-> cdc.Write(TempBuffer, 0, TempBuffer.Length);
This works fine.
Then I need to reboot my device - if a fatal error shows up.
-> PowerState.RebootDevice(false, 1000);
Under the reboot the ComPort goes away in the Windows Device Manager.
Then it shows up again when the device is running and CDC called again.
BUT, now I get no data in the Terminal program. Even not if the port is closed and reopened.
When I close the Terminal program and restarts it, then I cannot see the ComPort in the selection list.
But, it exists in the device manager!
I have tried with several programs and I see the same problem - the CDC is not working after a device reboot.
Same problem is seen if the USB cable is unplug and repluged.
What goes wrong?
