I have one more CDC related suggestion. [em]Read[/em] method works a bit differently in 4.3, it now throws “Operation timed out” exception.
Dim _cdc As New Cdc()
Dim cdcBuffer(255) As Byte
_cdc.Stream.ReadTimeout = 0
Do
_cdc.Stream.Read(cdcBuffer, 0, 256)
Loop
Using this peace of code, I will be getting exception almost every single time. As we know, handling exceptions are not efficient and will slow this loop significantly. I would like to suggest adding [em]BytesToRead[/em] property (SerialPort class has it).
@ iamin - A BytesToRead property would definitely be helpful, but it isn’t as easy to add as the other property was. We will look into it though for a future release.
[quote=“John”]
@ iamin - You can sent ReadTimeout to Timeout.Infinite to block in the function forever until data is available in the next SDK.[/quote]
[em]Timeout.Infinite[/em] option is a good addition, I was missing it as well but I could live without it.
However, [em]Timeout.Infinite[/em] does not solve the issue I am having with exceptions (I make an assumption here because I have not seen how exactly you have changed things). If I ask to read 256 bytes but there are only 10 bytes available after 1 minute, another 10 bytes available after one more minute and so on - it will block my function for 25 minutes. I could reduce 256 to 1 byte but then reading data would not be efficient if large chunks of data are received.
One of the options would be using derived classes but this request is pending :
That explains how you have managed to respond so quickly to my previous request with [em]LastWritten[/em] 8)
@ iamin - Right. If you know the frequency and amount of data arriving, you can optimize around that. But we will still look into BytesToRead for the case when you don’t.
