Hi all,
I want to do a project with the enc28 ethernet module and the cerberus but have fallen at the first hurdle…
After seeing that you can’t add the module to the designer because of a bug I tried adding it programatically with the following line:
GTM.GHIElectronics.Ethernet_ENC28 ethernet = new GTM.GHIElectronics.Ethernet_ENC28(6)
But for some reason when I try and run this (with no other code whatsoever) I get the following error on that line:
Not sure in which array the index is out of bounds. Have I done something disastrously wrong?
Poncho
