This is probably painfully basic and I have looked in the documentation for guidance. However most of it is for 4.2 or 4.3.3 with significant differences for 4.3.4.
Raptor with an ENC28 module on Socket 1 (tried 3 as well) and a USB/Power module on Socket 8.
I can ping the board and it shows up in my router’s wired device list.
public partial class Program
ethernet.UseThisNetworkInterface();
ethernet.NetworkSettings.EnableStaticIP("10.0.0.20", "255.255.255.0", "10.0.0.1");
ethernet.NetworkInterface.EnableStaticDns(new String[] { "10.38.44.1", "10.0.0.1" });
ethernet.NetworkUp += ethernet_NetworkUp;
ethernet.NetworkDown += ethernet_NetworkDown;
if (ethernet.IsNetworkUp) break;
Thread.Sleep(1000);
Debug.Print("Waiting");
Thread.Sleep(5000);
Gadgeteer.Networking.WebServer.StartLocalServer(ethernet.NetworkSettings.IPAddress, 80);
Gadgeteer.Networking.WebEvent hello;
hello = Gadgeteer.Networking.WebServer.SetupWebEvent("hello");
hello.WebEventReceived += new WebEvent.ReceivedWebEventHandler(hello_WebEventReceived);
void ethernet_NetworkDown(GTM.Module.NetworkModule sender, GTM.Module.NetworkModule.NetworkState state)
Debug.Print("Down!");
void ethernet_NetworkUp(GTM.Module.NetworkModule sender, GTM.Module.NetworkModule.NetworkState state)
Debug.Print("Up!");
void hello_WebEventReceived(string path, WebServer.HttpMethod method, Responder responder)
Debug.Print("hello");
string content = "<html><body><h1>Hello World!!</h1></body></html>";
byte[] bytes = new System.Text.UTF8Encoding().GetBytes(content);
responder.Respond(bytes, "text/html");
When I run this I get the following in the output window:
Program Started
Waiting
Waiting
Web server started at http://10.0.0.20:80/
Down!
Up!
Which seems fine. It then sits until I access from a browser:
http:\10.0.0.20\hello or http:\10.0.0.20:80/hello or any other combination of / and .
at which point in the output window I get:
#### Exception System.IndexOutOfRangeException - 0xa9000000 (6) ####
#### Message:
#### Gadgeteer.Networking.Responder::FindHeaderSection [IP: 0034] ####
#### Gadgeteer.Networking.Responder::Parse [IP: 004b] ####
#### Gadgeteer.Networking.WebServerManager+Server::ProcessRequest [IP: 0090] ####
A first chance exception of type ‘System.IndexOutOfRangeException’ occurred in Gadgeteer.WebServer.dll
The thread ‘’ (0x6) has exited with code 0 (0x0).
So it appears that something gets through but is not being handled properly.
If I unplug the Ethernet and plug it in after the system boots, there is no difference except a whole bunch more “Waiting”
